GlideOn-Designs
Working on 79' Twin Reverb UL and the popular mod that others claim to do is to have the NFB on a variable or switched control.
Okay.
Ground switch has been freed up and there's maybe room for a petite pot with a very small knob on the rear faceplate as the hole is higher up near the lip of the chassis.
I see it in the circuit as the 820ohm before the speaker jack, but there's also a .01 cap in parallel seemingly to cut some highs late in the circuit which got me thinking...
I'm thinking a 10k‐25k pot with a series 470ohm resistor to set the total useful NFB control range.
However, in regards to this 'icepick cap' also in play which likely would be detrimental to altogether eliminate, could this cap value scaled larger corellating to the decreasing NFB resistance for a combined NFB/High Cut?
Basically a "Clean/Dirty" control?
Okay.
