Installing a 3 prong cord on a 1953 5c1 Fender Champ?
Discussion in 'Amp Central Station' started by scottiel, Jul 30, 2013.
  1. scottiel
    scottiel TDPRI Member Vendor Member
    Vancouver, BC
    Hi Everyone,
    I recently picked up a 1953 fender champ (5c1 circuit). It has had recent work done including some of the caps and resistors, a speaker out (switchable 4/8 ohm), and a new 2 prong cable added. It works very well and sounds great, but every once in a while i'll get a light, pin and needles type shock.
    My Questions:
    - Is a 3 prong conversion doable/advisable on the 5C1 champs?
    - What is the approximate cost of the job?
    Pics of the amp for those curious: http://imgur.com/a/Zkb42
  2. andyfromdenver
    andyfromdenver Friend of Leo's
    grandpa's
    Yes
    30-45 min of someone's time (rates vary) + a cord ($10-15).
    $50 if a cool tech
    $100 if a greedy tech (assuming no other work done).
    (All values within a 20% tolerance due to cost of living) (bad joke...)
    Edit, you do realize more pics are in order :).
    Cool score! Did you see the guts and what the amp has had done? I guess it has a new Output transformer? Did you get the original in the deal?
    Do you have a variac? :)
  3. alnicopu
    alnicopu Friend of Leo's
    The city
    Yes it's doable and advisable. I had a champ with a 2 prong cord and got bit quite a lot especially when on a concrete floor. Retrofit before you play any more or you'll get wary of playing it. Remove any death caps that may or not be there if its been recently serviced. It worth to pay to have this done
  4. scottiel
    Vancouver, BC
    Thanks for the info guys! Here are a couple more shots (close up of the new handle, and one of it in its current home).
    http://imgur.com/a/Xt971
    I haven't had it open and I'm not sure about the OT, it was a good deal either way (swapped my old Premier drum kit for it which was taking up way too much space).
  5. Amstrat
    Amstrat TDPRI Member
    Toronto Canada
    Did the same cord Change on a 1957 Gibson GA-5. Very similar amp. Mine has all original tubes and speaker. Looks about four years old. No marks and a shine gold logo on the front. Needs a new handle though.
  6. Amstrat
    Toronto Canada
    Sorry multiple pics!
  7. andyfromdenver
    grandpa's
    I'm not sure either, the original did not have multiple ohm outs which makes me curious, but maybe it's some weird switch thing I'm not aware of.
    Nice find :)
  8. old goat
    old goat Tele-Holic
    Donner Lake
    The reason the old tweed is so dark is that the previous owners were all electrocuted.
  9. pete-strych
    pete-strych Tele-Holic
    Put the 3-prong cord on yourself if you're handy with a soldering iron. I zapped the daylights out of myself once working on an old Champ
    Sent from my iPhone using TDPRI
  10. Justinvs
    Justinvs Poster Extraordinaire
    Wise River, Montana
    Question. Is there a way to ground a two prong amp with an alligator clip and a wire to a ground source?
  11. pete-strych
    Answer:
    Clip one end to the amp chassis, and the other to the center screw of an outlet....or just come to senses & use a 3-prong cord (just kidding). That should work fine for say a bedroom amp.
  12. Harpboy
    Harpboy TDPRI Member
    Whitby
    I know I'll get flamed for this, but I have a '56 Magnatone (have owned and gigged with it for years) and it still has the original two-prong cord. I've been snapped a few times, but about 10 years ago, I determined which way the plug should be inserted to result in grounding (in North America, this is the left-most slot in the outlet, usually wider than the right one) and notched the top of the plug on the cord so I always plug it in with the same orientation. I know there are "risks", blah, blah, blah, but it's worked for me for years, and I prefer not to change out the original cord. I've never been snapped since.
    But if you choose to have it done, it's fairly trivial to do, or to have someone do it for you.
  13. andyfromdenver
    grandpa's
    Haha. I don't think that's flame worthy :)
    That is one solution, especially if it's an heirloom type amp.
    +1 on the idea to DIY. That's a good learning experience, if you don't have any of the tools though and no desire to use them again you should just get a pro to do it.
