Input Jack Constantly Coming Lose
Discussion in 'Telecaster Discussion Forum' started by SonicDiveBomb, Jun 10, 2015.
  1. SonicDiveBomb
    SonicDiveBomb Tele-Meister
    Philadelphia
    I have a 2015 Mexican standard and this input Jack will not stay tight. I'll tighten it up so there's no play at all and with a few plugs/unplugs of a 1/4" cable it's back to being lose again. Is there any fix for this? Is buying a new plate and bolt my only one?
  2. newtwanger
    newtwanger Blackguardian. Ad Free + Supporter
    Quebec, Canada
  3. 6942
    6942 Poster Extraordinaire
    Santa Fe, NM
    You could put a little RTV on the threads, to keep the nut from backing off.
  4. Textele
    Textele Tele-Holic
    Go with the Electrosocket and you will NEVER have to worry about it again.
  5. Alamo
    Alamo Doctor of Teleocity
    Berlin
    You could secure it with thread locking lacquer ....but if you have to buy that stuff it's better to get yourself an electrosocket and be done with the issues.
    probably the same price, perhaps even cheaper.
  6. Alamo
    Berlin
  7. regularslinky
    regularslinky Tele-Afflicted
    NEPA USA
    This. I have switched all of mine out for this far superior design. I can't believe Fender still uses the crappy ones.
  8. charlie chitlin
    Spring City, Pa
    Put a star washer (internal tooth) on the inside and tighten the nut.
    Not under the nut (although you could do this, too), but between the jack and the plate.
    I put one of these on every guitar that doesn't have one and never have jacks come loose.
    Cheap and easy.
    And...it's an output jack ;)
  9. Nick Fanis
    Athens-GREECE
    +100
  10. loudcherokee
    loudcherokee TDPRI Member
    Pittsburgh
    A dab of clear nail polish on the threads will secure it in a pinch.
    LC
  11. Mike Simpson
    Gilbert, AZ (PHX)
    I have changed all mine to an electrosocket or aftermarket copy of one. I usually buy one that comes with a new jack so I know the threads fit together. There are some copies made that have metric threads so you need a matching jack.
    http://www.ebay.com/itm/New-Satin-C...069?pt=LH_DefaultDomain_0&hash=item19ffae89fd
    http://www.ebay.com/itm/Electrosock...025?pt=LH_DefaultDomain_0&hash=item20fab04729
    While the stock Fender design can be made to work correctly by replacing the bent metal plate with a thicker piece and buying an installation tool to get it properly spaced for depth and wedged in the wood it is still more reliable to replace it. The bent metal clip for the jack socket may be the most poorly designed part that Fender ever made.
  12. SonicDiveBomb
    Philadelphia
    So I opened up my tele and pulled out the input jack and sitting in the cavity for the jack was one of those crown washers?? Haha did fender forget that they're supposed to go ON the input jack? I put it on and now it ain't moving. Thanks for the help anyways guys!
  13. Birdmankustomz
    Birdmankustomz Friend of Leo's
    New York
    I replaced mine with a plate, I know it's not 'vintage correct' but I didn't want to have to deal with it again. I was too broke at the time to buy electrosockets and I had them laying around.
  14. String Tree
    String Tree Doctor of Teleocity
    Up North
    You beat me to it.
    I was about to suggest a Star Washer when I read your post.
    Time to Play Guitar!!!
  15. indiobravo
    indiobravo Tele-Afflicted
    Raleigh NC
    atta boy!!
  16. xFallenx
    xFallenx Friend of Leo's
    South Jersey
    The hammer in one looks cool , but I feel like I'm one of the only people who doesn't like the electrosockets :confused: I just don't like their look or the 2 mounting screws :oops:
  17. haggardfan1
    haggardfan1 Friend of Leo's
    Texas and Louisiana
    When I dismantled mine to install the Electrosocket, that retainer clip turned out to be some of the most pathetic metal I've seen--like folded aluminum foil.:(
    My install took about 20 minutes, including a test fitting or two for depth. Don't waste your time adding lock/star washers, Loctite, glue, or anything else to the factory design--buy an Electrosocket for a few dollars and be done with it.
    (As an added bonus, Electrosocket jack depth can easily be set to accommodate a right-angle plug; most of the Teles I've owned would not, with the Fender setup.)
  18. vintage clubber
    vintage clubber Friend of Leo's
    Mechanicsville, VA
    This!
  19. sacizob
    sacizob Friend of Leo's
    Middlesex County, MA
    Fender must have made some good ones! I've never had a problem with my heavy used 2007 Hwy 1.
  20. Scotty 2
    Scotty 2 Tele-Holic
    Port Saint Lucie,Florida
    I like the electrosocket,don't care about looks. I want the guitar to "play".
