Input grid resistor?
Discussion in 'Amp Tech Center' started by dougstrum, May 5, 2021.
  1. Lynxtrap
    Lynxtrap Tele-Afflicted
    EU
    LightningPhil and dougstrum like this.
  2. the fatch
    the fatch Tele-Meister
    LEEDS UK
    It only cuts frequencies way out of human hearing. As the capacitance is increased, it will eventually cut treble. With a 2.2nF (0.0022uF) capacitor, response would begin to fall off at around 7.2kHz. Guitar amp speakers output very little over 7kHz, so over 2.2nf would begin to cut treble.
    dougstrum likes this.
  3. LightningPhil
    LightningPhil Tele-Meister
    Nottingham, UK
    A ferrite bead around the cable from the jack to the first resistor could help keep a bit of RF (mobile phone induced hum perhaps) out too. Not seen it in a guitar amp, but quite common on old electrical engineering kit.
  4. Euphonica
    Euphonica Tele-Meister
    New Orleans, LA
    Whoops yes I meant to say the same thing about ferrite beads. I used to hear radio stations until I put one on the main surge protector. Not heard anything since!
    dougstrum and hepular like this.
  5. LightningPhil
    Nottingham, UK
    The resistor could be replaced with a choke like one of these:
    https://www.mouser.co.uk/ProductDet...EpiMZZMv126LJFLh8y%2B2RKwC9HhBzm%2B//EIaqABA=
    It has a DC resistance of 490 ohms and at 10 kHz, it’s got 6280 ohms of inductance impedance too. However, it’s resonance with a 200pF Miller capacitance gives a huge spike at 35 kHz which is not useful. It would require a 33k resistor in series to have a sensible Q of 0.67. So some caution should be used.
    Interestingly, 10 of the chokes in series with the Miller capacitance increased to 1nf would give a resonance of 5khz and a Q of 6. The ultimate passive top boost? An additional 10k resistor in series would drop the Q to 2 which is much more sensible.
    Here’s a calculator for reactive impedance:
    http://www.learningaboutelectronics.com/Articles/Inductor-impedance-calculator.php#answer
    And for RCL circuits:
    https://www.omnicalculator.com/physics/rlc-circuit
