Inductive Cooktop Not Working
Discussion in 'Bad Dog Cafe' started by Gardo, Jul 9, 2020.
  1. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    Does anyone have any experience with inductive cooktop problems ? I sure could use some help We have a GE Inductive cooktop model PHP900DMBB . It's about 7 1/2 years old and always worked great. Today my wife was boiling water in a large pan and heating oil in sauce pan when I heard some popping from the sauce pan. I reached over and lifted it uo a little and saw what looked like an arc between he glass surface and the pan The cooktop lost power. I walked to the basement to check the breaker and found it tripped. I reset the breaker and headed back to the kitchen Treid the cooktop again but all we got was all of the fashing E . I hit the control lock and then unlock, no more E until I tried to heat a pan then the E came back on that burner only. Result is a non functioning stove . the timer works and so does the control lock but no heat
    Thanks
  2. stxrus
    stxrus Poster Extraordinaire
    St. Croix, USVI
    Not any help here. Totally propane. But the few inductives I know about here are not looked on favorably.
    I look forward to the replies
    Gardo likes this.
  3. Peegoo
    Peegoo Friend of Leo's
    Planet Peegoo
    Search for a schematic for your model online (or dig out the manual if you have it). It will show a circuit breaker or multiple breakers in the diagram. Sometimes they're manually resettable, and sometimes they're simply a thermal fuse that pops and must be replaced.
    Thermal fuses are a big failure mode for glass cooktop stoves and automatic coffee makers.
    They good news is a replacement fuse costs about a dollar. The bad news is you have to take it apart to get to it. The bad fuse is clipped out and the replacement is crimped on using steel crimp sleeves because a solder connection will melt on use. If you figure out one of the thermal fuses is bad (use a meter and check continuity across it), don't replace that one. Replace 'em all because they have a life span.
  4. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    Hey Thanks ,I'm on it and I will let you know what I find
  5. otterhound
    otterhound Poster Extraordinaire
    Manheim Pa.
    I'll stick with gas and cast iron . Good luck .
    Jim622, electrichead and Gardo like this.
  6. HoodieMcFoodie
    HoodieMcFoodie Doctor of Teleocity Ad Free Member
    Tamworth, 'straya.
    Have you lost cooking function across all the hotplates or just on one?
  7. Peegoo
    Planet Peegoo
    Sometimes the heat element goes bad and must be replaced.
    The E code is an error and the controller may have a hidden reset function that's published only in the factory service manuals. Which can really suck for us DIY types.
    Gardo likes this.
  8. HoodieMcFoodie
    Tamworth, 'straya.
    Wally and Gardo like this.
  9. HotRodSteve
    HotRodSteve Friend of Leo's
    The Shmudson Valley
    I can't help you either but my new house came with an inductive stove and it sucks. Boiling water with a copper bottom tea kettle takes forever and cooking on the range the pan temp is either too low or red hot, very hard to control. My next house will have an electric stove with the coils.
    61fury likes this.
  10. koen
    koen Friend of Leo's
    home
    Sounds like advice for a 5E3 that's not working - lol
    Gardo likes this.
  11. Peegoo
    Planet Peegoo
    "IMPORTANT: If the “E” flashes alone, without alternating to a “c” or “o”, a hardware error has occurred. Call for service."
    Well there ya go. Something has hard-failed and needs servicing.
    RodeoTex and Gardo like this.
  12. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    Lost cooking on all
  13. scooteraz
    scooteraz Friend of Leo's
    Peoria, AZ
    If you saw arcing of your inductive element, it is fried. Hopefully it did not take the control board with it.
    Looks like inductive heating elements are between $100 and $250 each, depending on wattage. Couldn’t find the cost of the control board. The induction assembly kit appears to be about $300.
    Gardo likes this.
  14. 61fury
    61fury Friend of Leo's
    knoxville, TN
    I know those open coils are cheap and unloved but I have come to appreciate mine.The heat is steady and very controllable and you don't need much of it after it comes to temperature. When I'm cooking on my friend's gas stove I'm always fighting with/adjusting the burners.
  15. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    We discovered that pressing and holding the control lock and timer together causes an alternating flash of E and 5. If this is the correct way to get a code it would indicate internal electronic failure on filter board
  16. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    Thanks I have this already but didn't find too much real help in it
  17. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    i was surprised to see n arc through the glass top
  18. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    i really like the stove overall. copper bottom kettles are not the best choice though. The stove cooks with magnetism and copper is not magnetic. I set my frying pan to 71/2 give it a minute or so to heat and I'm frying spam and eggs
    saltyseadog likes this.
  19. HotRodSteve
    The Shmudson Valley
    Well that makes sense if magnetism is involved, I'll have to boil water in the microwave for now. Not sure what 71/2 means, the stove burners (and that's what they do) have dials that go from Hi to Lo. I'll live with it until I build my house and get a proper stove.
    Gardo likes this.
  20. scooteraz
    Peoria, AZ
    If that is really what happened (actual heater to pan arc through the glass) that would be bad. Really bad. As in replace not only the affected element, the inductive assembly but also the glass top bad, at least potentially. Hopefully that was some sort of optical illusion.
    Gardo likes this.
