If you use Chrome, you can click on the row of three vertical dots in the upper right hand corner. You'll see a menu that includes "Zoom" which will allow you to increase the size of everything. You can also select "Settings" which will give you a menu that includes "Appearance" which has some options for font size and page size.
But then this will apply to all sites you go to right?If you use Chrome, you can click on the row of three vertical dots in the upper right hand corner. You'll see a menu that includes "Zoom" which will allow you to increase the size of everything. You can also select "Settings" which will give you a menu that includes "Appearance" which has some options for font size and page size.
That was available yesterday, I played with it for a good amount of time. It appears to be gone now, unless it was moved a bit deeper into some of the menus.I swear there was some odd, out of the way place I discovered since the upgrade where you could change the themes... choices were, I believe Core, Classic, Tablet, and Mobile. The differences between Core and Classic are pretty distinct, and might be of help for you folks... but I can't for the life of me find that setting now!
I should have specified that I did this on an old MacBook Pro.None of that works in Chrome on Android. You can increase the size in Chrome's Accessibility Settings, but that only affects a few things, and not the standard text/font in posts. Increasing it to 200% on my Pixel 5 does bizarre stuff...
Yes. On my old MacBookPro, there was a significant improvement just zooming to 110%.But
