We moved into a new house in September '21, which had been extensively upgraded/remodeled by previous owners, including a finished basement with tile floors and built-in shelves. One room in the basement is surrounded on two sides by closets housing the HVAC unit, hot water heater, electric service panel, and the (rather noisy) sump pump. One thing we noticed straight off was that all the doors were missing from this room. In all there were empty frames for four hinged doors and on double-wide set of bi-fold doors. Oddly, we found all the hinges in a bucket, neatly labeled each with it's own letter, which matched letters written in Sharpie on the mortises in the door frames.
We search the house; no doors. We contacted our realtor, where are the doors?, Our realtor contacted the listing agent, who presumable contacted the previous owner (who was moving into assisted living). Nobody knew where the doors were, so the _S family were SOL.
My son stays with us part-time and the larger basement room serves as his living space. Since the other room is where all the noisy equipment is, we'd really like to have a door between the two rooms. The trouble is, when the remodeling previous owner finished the basement, he didn't box in the HVAC ductwork, he simply lowered the whole ceiling. AS a result the ceilings are LOW and the door openings are only 70 inches high. Standard widths, but 70inches high. All the doors I'm looking at on the Home Depot website say they can only be trimmed 1/4" off each edge. I find this hard to believe on the (expensive) solid pine 6-panel doors, which seem to have solid top and bottom rails that could be trimmed down several inches, but taking ten inches off a door is an awful lot. It would leave very little top and bottom rail, possibly weaken the door, and make the recessed panels look weird.
Another possibility would be hollow-core doors. If I trimmed one of those that much, I'd be left with an open edge, which I would them have to fill with a piece of wood, glued in and screwed through the vertical side rails. I did this once before and it's a tedious work for one door, let alone four. Also, the garage is still so full of junk (16 months after we moved in) that I still haven't been able to set up my work shop, including the table saw that would be required to rip down the custom-sized fillers strips.
Suggestions? I can't think of a way to do this that isn't a total PITA.
