In praise of vintage style tuners
Discussion in 'Telecaster Discussion Forum' started by naveed211, Sep 21, 2020.
  1. TeleTown
    TeleTown Friend of Leo's
    Twangers Medows USA
  2. Strebs
    Strebs Tele-Meister
    NE Texas
    I like them fine. My only problem with them is the high e and b string can sometimes be problematic. Probably because there's a technique I don't know. That being said, I'll take locking tuners all day long over them. I loathe string changes and it's so much easier to pull the string through, lock it down, and tune. With vintage split, I've got to find a string winder and keep some extra strings on hand for my mistakes.
    djp141 and drmordo like this.
  3. Digiplay
    Digiplay Tele-Afflicted
    Hoover, Alabama
    Model/Part Number?
  4. 8trackmind
    8trackmind Tele-Afflicted
    Dark side of the moon
    SKU:KD-6B-NM]
    Specifications:
    • Gear Ratio= 15:1
    • Post to Post spacing= 15/16 in.
    • Bushing size 8.8mm O.D. x 1/4 in. I.D.
    Greggorios likes this.
  5. Digiplay
    Hoover, Alabama
    Darn, it was the 18:1 gear ratio that first caught my attention.
    But thanks for the quick reply!
    Jerry
  6. beachbreak
    beachbreak Tele-Meister
    I like them but I use a toothpick on the high E and B strings because I've had them pull out of the hole when restringing. I put the string end in the hole, insert a toothpick then clip it flush, then tighten. It works good.
    jays0n and El Tele Lobo like this.
  7. Telecastoff1
    Telecastoff1 Tele-Afflicted
    Blizzardville
    It took me a while to get used to them all over again after not having anything with them. But now it's easy as pie again.
  8. SPUDCASTER
    SPUDCASTER Poster Extraordinaire Gold Supporter
    Grangeville, Idaho
    The "Original" locking tuner.;)
    El Tele Lobo and naveed211 like this.
  9. wyclif
    wyclif Tele-Afflicted
    Philadelphia
    Those are great. Where did you get them...who is the manufacturer and what is the part #? Asking for a friend!
  10. 1996Standard
    1996Standard Tele-Meister
    Oklahoma
    My strat has those vintage split shaft tuners. Really great.
    Tele_Luvr and naveed211 like this.
  11. wyclif
    Philadelphia
    IMHO the vintage Klusons (and the reissue versions from Gotoh and others) are the superior design. They fit the design aesthetic of Fender guitars perfectly. Other reasons to like them:
    1/ Easy to change strings
    2/ No string ends to gouge you or others
    3/ Light; you might think this doesn't make a difference but it does, especially if you want to avoid neck dive
    4/ Sleek and low profile, especially the rear housing
    The oval tuning heads just look better on a Fender headstock IMO. If you're having trouble with your high E and B strings, one tip I've found that helps tremendously is to avoid wrapping more than three winds around the post. On the low E string, you can get away with two winds. This will prevent any slippage.
    Tele_Luvr likes this.
  12. Greggorios
    Greggorios Friend of Leo's Silver Supporter
    NY
    On 50s and 60s style Fender guitars anything else just doesn't look right.
    El Tele Lobo and Tele_Luvr like this.
  13. Digiplay
    Hoover, Alabama
    Same question :)
  14. pcampbell
    pcampbell Tele-Meister
    Memphis, Tennessee
    I prefer the split shaft vintage tuners too. They're on the 2 teles shown in my avatar.
  15. ieatlions
    ieatlions Tele-Holic
    Wales, UK
    Gotoh Staggered. Mine are the aged nickel set, they also offer nickel and gold if memory serves.
    I bought them from a supplier here in the U.K. for around £45. So they’re not cheap but they are superb quality. The bridge on my Tele is Gotoh with the compensates saddles. Great hardware.
    wyclif likes this.
  16. burntfrijoles
    burntfrijoles Poster Extraordinaire
    Somewhere Over The Rainbow
    I concur. They’re amazingly simple and fool proof.
  17. El Tele Lobo
    El Tele Lobo Poster Extraordinaire
    This is a great idea!
  18. beagle
    beagle Friend of Leo's
    Yorkshire
    My only Strat with stock "vintage locking tuners" soon got upgraded to Gotoh SD91 vintage not locking tuners.
  19. Owenmoney
    Owenmoney Tele-Afflicted
    Perkiomenville Pa
    I definitely prefer the vintage tuners. my wife doesn't have to worry about strings poking her when I leave guitars all around the house.
  20. stormsedge
    stormsedge Friend of Leo's
    E. Tennessee, USA
    LOL. How timely! Last night, I did a string change on my long ignored Nashville Deluxe...and, after struggling with it a bit trying to string it the way the previous owner had, I thought "it'd be easier to just stick the end of the string in the hole". Looked it up and "duoh!"...that's the way, uh huh...worked much better that way. ;)
