Importing files?
Discussion in 'Recording In Progress' started by clayton58, Jul 3, 2020.
  1. clayton58
    clayton58 TDPRI Member
    On the Bayou Teche
    Okay. I’m recording with a MacBook Pro, using Presonus Studio One.
    I sometimes just do sketch stuff on Garage Band. (because it’s faster)
    Why won’t either DAW let me import from each other? Thanks.
  2. erratick
    erratick Tele-Holic
    SoCal
    They use different formats. There is no incentive for Apple to help you move from Garageband to presonus- they are encouraging you to upgrade to Logic. They won't program the ability to read presonus format. If they did, it would be in Logic.
    In addition to monetary incentive, the formats maybe proprietary.
    Presonus maybe has some incentive to import from other apps to get you to switch to theirs, but they haven't for whatever reason done that. See file format maybe proprietary.
    However:
    You can export WAVs from 0:00:00 and import in the other (manual import for stems). That will not really do the midi stuff per:
    https://forums.presonus.com/viewtopic.php?t=7318
    The other way is upgrade to Logic, and use AAF formats between the two:
    https://www.musicradar.com/how-to/7-things-you-might-have-missed-in-presonuss-studio-one-4
    Logic is like Garageband on steroids.
    Your last option is just use one or the other.
    There maybe some other options- because I don't use Presonus stuff, but these are the options I've used with Garageband and other apps.
    Biffasmum and clayton58 like this.
  3. clayton58
    On the Bayou Teche
    Thank you.
  4. Ed Driscoll
    Ed Driscoll Tele-Meister
    South of Dallas
    There are also file conversion programs. Izotope's RX supports AIFF, and can convert it to WAV. I'm sure you can find stand-alone file conversion programs as well.
    clayton58 and fendrguitplayr like this.
  5. fendrguitplayr
    fendrguitplayr Doctor of Teleocity
    Greater Boston
    clayton58 likes this.
  6. Biffasmum
    Biffasmum Tele-Meister
    Melbourne
    As erratick said GB is a cut down version of Logic Pro. You can import GB projects into Logic through iCloud though. Same the world over - software vendors want you to buy into an ecosystem.
  7. erratick
    erratick Tele-Holic
    SoCal
    Manual import for stems always works- it may remove a little opportunity to tweak. But it works pretty well.
