Import (cheap) switch wiring diagram help
Discussion in 'Tele-Technical' started by HOBBSTER01, Sep 1, 2012.
  1. HOBBSTER01
    HOBBSTER01 Friend of Leo's
    Ringgold, Ga.
  2. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    tewiq likes this.
  3. HOBBSTER01
    Ringgold, Ga.
    Thank you
  4. bigmuff113
    bigmuff113 Friend of Leo's
    San Antonio tx
    He's alive!!
  5. HOBBSTER01
    Ringgold, Ga.
    And kicking.
    Been focusing on rehab and lost my step father-in -law when he fell in his kitchen and broke his neck. It happened 3 weeks ago and we've been busy with dealing with his affairs.
    Been a real tough summer.
  6. oldteleguy
    oldteleguy Tele-Afflicted
    wallingford,ct.
    Hi Tim,
    Sorry about your father-in-law.You have been wading through a very large pile of hurt lately
    I'm very happy to hear that you are recovering.Best wishes to you,and your family!
  7. HOBBSTER01
    Ringgold, Ga.
    thanks sir. kind words are healing as well.
  8. bigmuff113
    San Antonio tx
    My condolences hobbster
  9. mPetetele
    mPetetele Tele-Meister
    Hackettstown NJ
    Sorry for your loss as well.
  10. Juststrumsum
    Juststrumsum NEW MEMBER!
    Fishersville Va
    I have a switch in my tele just like this. My neck pickup stopped working, well it just went to very low volume bridge is fine. I dont know if its the pickup or switch?
  11. user34603
    user34603 Tele-Meister
    Richmond VA
  12. user34603
    Richmond VA
    I have a switch like this is in a cheap Washburn Tele style guitar. The bridge and neck pickups sound normal, but the middle position has a volume loss. The tone may be the right one, but I don't understand why the volume of the output for middle position (both pickups) is so weak. Ideas ? I had wired in a new bridge pickup (hot yellow and ground black ) and it seems to work fine alone.
  13. dsutton24
    Illinois
    Easy... your pickups are out of phase in the middle position. I don't know anything about the Washburn, but what you need to do is disconnect the ground and hot from one of the pickups, reverse the wires, and resolder both connections.
    The reason that 'Washburn' might be a factor is that I don't know if they ground covers, baseplates, etc. Swap the wires on one of your pickups. One of two things will happen. 1) It will work great, or 2) the middle position will be silent. If it's silent, snap pictures of the backs and fronts of your pickups, as well as your wiring and post them here. Somebody will be along and help you out.
  14. user34603
    Richmond VA
    Nope ... that is not right. Reversing the 2 bridge pickup wires to their contact points just makes for a hum. I am going to do the simple solution: disconnect all the wires to the cheap 8-in-line offshore switch and throw it in the trash. I will get a standard 3 way switch for a Tele from the US like a Fender type and wire it up standard 3 position Tele style. Some stuff is not worth fooling with and the offshore switch was wired in by a poor teenager in China somewhere. The annoyance is not worth the few dollars to fix it once and for all. Thanks anyhow.
  15. Bartholomew3
    Bartholomew3 Friend of Leo's
    Montreal
    If you turn down the guitar tone control on the weak p/u and the volume goes away then it's blown.
  16. dsutton24
    Illinois
    Okay! Way to take a stand! But, the problem's not the switch. You'll figure that out eventually.
  17. user34603
    Richmond VA
    Fellows... thanks for the ideas, but the problem was very low output in middle Tele position and reversing the wires for the new bridge pickup did not help. So no use in speculating ... just remove a switch that is cheap offshore stuff and get a decent Fender style 3 way or 4 way Tele switch and solve the problem simply. I have wired up maybe 10-15 Teles with 3 way and 5-6 with 4 way switch and never a problem. But the close-together tabs and cheap quality of the offshore 8-tabs type frustrated me at every turn in several guitars. The few dollars for a new switch that is well diagrammed and easy to reach each tab is the simple solution.
  18. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    Those are nice features, but I think you just need a louder one. ;)
  19. user34603
    Richmond VA
    ...whatever 'those are nice features' or 'you just need a louder one' is supposed to mean. Skip the wink emoji and say what you mean.
  20. LutherBurger
    NYC
    It's been nine months. I don't remember. ;)
    :p
