Greetings to all! its been a while! combination of Retiring, moving and other life stuff plus a pandemic all took my time. Anyway..
I built a variant of the PA 26 about 8 years back and was pretty pleased with it at the time. I drilled the chassis..built the head etc and liked the sound. it didnt get a lot of play because it was just too loud before it really sounded sweet to me and also the noise floor was a bit annoying. So I have a few thoughts and questions... I am attaching the schematic from Scott Rubel I believe (which used EL 34s) and also the schematic from Stratman which used KT 66 tubes.
1) The original layout on a very small chassis put the PT (Hammond 273BX) closer to the OT (Hammond 1760J) than I would have liked so I thought I would rehouse the amp in a larger chassis to better distance them
2) while doing that I also wondered how the amp would respond if I tried a tube rectifier rather than the diode rec I did use.
3) I hard wired V1 without a switch and was wondering how I might get a bit more gain at a lower volume
4) last question: I used a 1000uF cathode cap as per Stratmans diagram but noticed that Scott specified a 100uF in that position. not sure if that was a typo and that the correct value should have been 1000uF
thanks for any suggestions
Iggy
Iggy
