If I deck the trem, do I still need a larger trem block?
Discussion in 'Stratocaster Discussion Forum' started by A1exand3r, Nov 30, 2019.
  1. drlucky
    drlucky Tele-Holic
    Fresno, Ca
    I may have to try this...:cool:
    telemnemonics likes this.
  2. telemnemonics
    FD1EC725-3C66-4E08-B6BA-7E37AEB71E1C.jpeg 3E7A4C46-CF03-4997-A104-46037EC17143.jpeg 9271C44D-3A46-49D2-8CE2-940E73A34A92.jpeg 2C169FD1-AF84-40B5-8415-001062F65316.jpeg 2211188B-B593-4923-9176-5EF20CEC9A1D.jpeg
  3. telemnemonics
    Hard to see the pics in iCloud as they come up tiny on my iPad when posting on the forum but the above gives an idea of the process.
    drlucky likes this.
  4. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    Remember, Eric Clapton approves of blocking your trem.
    What matters to sustain is the amount of string beyond saddles and nut that can stretch and the friction of the strings on the saddles and nut. Think of a car with good/bad shocks and how it reacts after a pot hole. So put No.2 pencil lead on the contacts for more sustain.
    Average_Joe likes this.
  5. Zepfan
    Zepfan Poster Extraordinaire
    Horn Lake, MS
    I want to remove the trem on one of my Strats, block the hole with wood, install a Gibson style rollor bridge and a JM style tremolo. Or I could buy a JM?Jag and put whatever pickups I want in it.
  6. telemnemonics
    Blasphemer!
    Fretting out, rangercaster and Zepfan like this.
  7. Average_Joe
    Average_Joe Tele-Meister
    A rock and a hard place
    I swore off a trem in 1987, never again, never never, never again :)
  8. coloradojeff
    coloradojeff Tele-Holic
    Colorado
    I have the trem blocked on all three of my Strats. All three are blocked with a piece of ash. No difference from when they were unblocked. I should note that one of them was blocked by the Fender Custom Shop and the other two by a professional luthier.
  9. Dismalhead
    Sacramento, California
    I leave the trem floating, but rarely put on the bars. I like the extra slack when you bend with your fingers. One of the reasons I've always liked floating trems. It doesn't feel like a fixed bridge guitar.
  10. SamIV
    SamIV Tele-Holic
    South Louisiana
  11. A1exand3r
    A1exand3r TDPRI Member
    Virginia
  12. telemnemonics
    Came down to 6lbs 14ozs from 7.5 lbs so not that drastic but much more comfortable for my shot back.
  13. telemnemonics
    Some wood removed under the guard as well.
  14. Rumblur
    Rumblur Tele-Meister
    Upstate, SC
    I drank the TGP Kool-Aid, like an idiot. Swapped the 'thin' block in my favorite CV Strat for a big block. Guess what it did to the guitar? Tone wise, sustain wise, NOTHING.
    ALL it did was add 1lb to it.
    it's another "I wanna be like the cool kids" snake oil waste of money unless you like a heavier guitar.
    JL_LI and A1exand3r like this.
  15. lost sailor
    lost sailor TDPRI Member
    No. Central PA
    That wood block is a great idea, patent it and make some money!
    I'd buy some.
  16. reddy2300
    reddy2300 Tele-Meister
    Dublin, Ohio
    I have two with blocked trems. I used a block of wood in one (spring tension keeps it in place) and one with a stack of quarters (again, spring tension). They both sound more "alive" after the blocking.
    I just bought an ash body for the MiM one that has the wood block. Next time, I'll build a block like telenemonics did. What a great solution! I have a trem cavity block-off that doesn't quite fit so it sits in the drawer awaiting the correct time to use it.
  17. gregulator450
    gregulator450 TDPRI Member
    Tri-Cities, Washington
  18. Baconaire
    Baconaire TDPRI Member
    Cambridge
    I swapped the whole tailpiece on my CV for a Mex high mass an I think it made a significant difference. Best $30 I've ever spent on an upgrade. Maybe its not the block but it did make a difference.
  19. telemnemonics
    I'd have to hunt back through icloud pics but I'm pretty sure I just drilled from the trem rout above into the control cavity and sandwiched some thin wire between the bridge plate and the maple "trem block". Not from the back rout, the wire is not visible like original.
    Drilling through the block so the holes line up and don't wander out the side of the block is a little tricky, you can see the hole I drilled into the plywood drill press table and put a pin in, then flip the block and drill the ferrule holes from the back, followed by finishing the string through holes which were only drilled half way from the plate side.
    To ensure the block stayed at 90 degrees to the drill I clamped it to a longer piece so it couldn't tip on the narrow top edge.
  20. gregulator450
    I kinda figured you ran the ground wire through a new hole so it could be sandwiched. I am going to try to build one of these here in the next week or so. Looks like a fun little project!
