Newbcaster
how wide would a tele neck be if it had 24 frets, 25.5 scale?
What is the nut width?
what is the end width?
width at 24th?
width at 24th?
I have a fender standard strat bridge. I was just wondering if anyone knew off the top of their head. I don't think fret 2 find actually tells me this as a point of datum.Is this a trick question?
Whatever width is correct for the bridge string spacing.
If you have a bridge already, then you know the spacing, and you can do a bit of simple geometry to get your desired neck width.
Fretfind can do all of that and more.I have a fender standard strat bridge. I was just wondering if anyone knew off the top of their head. I don't think fret 2 find actually tells me this as a point of datum.
Just done a quick measurement on my tele and a 24-fret guitar. It would move the neck pickup back about 1 cm, which I don't think would change the tone at all.@Newbcaster
The nut width would not change. The neck's total length would increase by ~18.8% of the remaining scale distance for every additional fret on the neck, measured from the preceding fret. Ref: see the "rule of 18."
The biggest effect of a 24 fret neck on a Tele would probably be pushing the neck pickup's location toward the bridge. That does change the tone a bit--especially when playing position 2 on the switch.
What was the width of the fretboard at the 24th and at the end of fretboard?I built this guitar for my son's buddy last winter.
An HH offset, 25.5” scale, 24 fret.
The nut width standard, & neck pocket size standard. Hipshot hardtail bridge.
The neck ended up to be about 3/4” longer than standard, 21 fret, which puts the nut a bit further from the body, compared to standard, & moves the bridge closer to the neck pocket. So a little less room for pickups, between the heel of the neck & bridge.
Comparing to the Jazzmaster 22 fret, I built.
Here is the thread of the complete build.
Offset Build 25.5” scale & 24 fret
Scott
The same as it is on a 21 fret guitar. The neck route is the same, which works with the standard bridge.What was the width of the fretboard at the 24th and at the end of fretboard?
All good pointsWhy do you ask?
You can buy 24 fret necks with only the fingerboard extended so the fit to the body is the same as 21/22.
Each individual neck varies a bit even among Fender brand 21/22.
I prefer a 1 11/16” nut which technically makes the 22nd fret one iota narrower.
You will not succeed if making a body for a 24 fret neck you have not seen or spec’d hoping our comments will tell you the dimensions the neck pocket should be for a good fit.
It may be the same or bigger or smaller.
But isn't the fretboard trapezoidal?The same as it is on a 21 fret guitar. The neck route is the same, which works with the standard bridge.
Scott
Technically it is with the parallel sides (the "bases") being the nut and last fret. We don't think of it as a trapezoid because the bases are so short compared to the legs but it is.All good points
