if a tele body weighs 4 lbs. 8 oz. what's the final assembly weight gonna be?
Discussion in 'Telecaster Discussion Forum' started by vanguard, Jun 7, 2010.
  1. vanguard
    vanguard Friend of Leo's
    Charleston, SC
    any ideas? assuming the guitar is all put together.
    thanks.
  2. boris bubbanov
    New Orleans, LA + in the
    Somewhere between Seven and One Half and Eight Pounds, depending on which features are selected and not including WRHBs, more that 2 pots, or any form of whammy or Bigsby.
    Perfect!
  3. vanguard
    Charleston, SC
    cool! 7 1/2 lbs (give or take a couple oz.) is my ideal weight. that's what i was hoping for. i'll just be using lightweight, vintage glendale style stuff and a light maple neck. sounds good!
  4. Chewy
    Chewy Tele-Meister
    NY, USA
    You can always just attach some helium balloons if it comes out too heavy.
  5. jkingma
    45°54'36.6"N 79°59'11.5"W
    Admin Post
    It depends on how heavy the rest of the parts are... ;)
    But seriously, you should be able to keep it to about 7.5#.
  6. robt57
    robt57 Telefied Ad Free Member
    Portland, OR
    I have one with a 5.8 lb body [with finish] that is 7.8 lb as a guitar. I would say that is the light side. I did some things in an attempt keep the weight as low as possible. Plastic amp knobs, plexi control cover, Ti saddles, Vintage tuners & bridge plate, .060" 1 ply guard. These things each added up [or rather down] cumulatively to lower weigh a little. I was actually surprised the guita came in under 8 at all. Hope that helps...
  7. Codinho
    Codinho Tele-Meister
    Nashville, TN
    It depends if you use a henweigh.
  8. robt57
    Portland, OR
    And which species you use as well... :D:D
  9. vanguard
    Charleston, SC
    thanks for the great advice. sounds like if i keep it minimal i should come in at or under my desired weight no problem.
  10. robt57
    Portland, OR
    When I got the body of craig's list for 50.00 with a guard, my first thought was, Oh boy, a 9 lber. ;)
