I wired a Strat, pots behaving oddly
fraser
Hamilton, Canada
You have the cap on the tone pot, the green circle on that diagram, either not connected, or wired wrong. The schematic doesnt show the cap bridging the lugs on the tone pots.
are you saying the volume knob only functions from 10 to 9?
that schematic looks fine to me
edit
the cap goes one leg on pot casing, the other to lug one of that pot, then over to the wiper on the second pot
having a hard time posting a pic....
fraser
Hamilton, Canada
you can see more clearly here
wabashslim
Sonorous Desert
Maybe you have an audio taper vol.pot wired backwards?
.1 uF is pretty big, if that's what you're using, depending on your pickups...and are you sure it's a zero-point-one and not a one-point-zero? I'd try a .047 or .022.
Otherwise, something's funky in your wiring.
wabashslim
Sonorous Desert
The total lack of response is curious...and aggravating. Makes me wonder if he found something silly he's too bashful to fess up to.
Or maybe all our suggestions are crap.
ElJay370
Los Angeles, CA
I don’t see anything wrong with the diagram, unless you’re reading it incorrectly.
As others have said, pics would be very helpful
Greg M
Virginia
I had the cap wired wrong. The volume problem is likely a not so good pot. CTS is the way to go, but I didn't have any for this one. I'll get some later. The volume isn't actually cut off below 8 or 9, it's just super low.
I didn't post pics because it's pretty sloppy. It would be like letting everyone see me when I get up in the morning ;)
Thanks for all the help. Greatly appreciated.
schmee
Which pots you use is highly up for debate. Glad you got it sorted.
