I Want Something Like This
Discussion in 'The Stomp Box' started by Grandy, Jul 15, 2019.
  1. Grandy
    Grandy Tele-Meister
    Finland
    I got bored so I designed a pedal I'd like to have. I have no idea whether it's feasible or not. Maybe you can tell me what you think. It's sort of a drum machine. You don't really program it and it doesn't have complete patterns to play along with. Instead you combine different sounds and patterns to create rhythms. There would need to be some clever algorithm to make sure the different patterns fit.
    It looks like a four channel mixer. On each "channel" you can choose a sound/intrument. You could have a bass drum on one channel, then a snare etc. One channel could be dedicated to let's say different bass drums or they could be identical and it would be up to the user to mix them any way he/she wants to. The small box version could only maybe have two channels and a deluxe version more and maybe some fancy filttering and onboard effects.
    The idea is to keep it simple enough to be able to tweak during performance. It's not a production tool. There are already loads of good drum machines. And it is not a practicing aid or a drummer replacement. There are those kinds of pedals too. It's more tweakable than those but more simple than a proper drum machine.
    Fretting out likes this.
  2. TheTruth
    TheTruth TDPRI Member
    India
    Nice thought.
    So do we create drum / other patterns, store them as a preset & then use them ?
  3. Fretting out
    Fretting out Tele-Holic
    Land of Mary
    Just thinking here and it would probably be impossible but..... if it could be like a looper and each string has a different drum/ instrument you can record and save as a rhythm.
    Ex.
    1st string- bass drum
    2nd string -snare
    3rd string - high hat
    And so on......
    Or maybe something similar
    I don’t know if that’s possible or if you need midi to do that.
    Just kicking an idea around
    Either way I like your idea a lot and look forward to seeing one:)
  4. Grandy
    Grandy Tele-Meister
    Finland
    My thinking was that you don't trigger the sounds. The device would generate those on its own according to how it is set. It's more like tweaking a step sequencer on the fly, just not all the options.
  5. VintageSG
    Yorkshire
    Some broadly similar has been done in the Arduino community. Doing it any other way than with a microcontroller ( or something like a Raspberry PI for squits, giggles and over-the-topness ) would lead to convoluted workarounds with timers for sync.
