I suddenly don’t like my Tubescreamer anymore
Discussion in 'The Stomp Box' started by marcflores, Aug 5, 2019.
  1. marcflores
    marcflores Tele-Meister
    San Francisco
    Yep, that's exactly the case as everyone has told me. It makes the perfect excuse to go to GC, pull a Tele off the wall, plug into a Vox and make a day of testing out pedals. Haha.
    Mexitele Blues and RetroTeleRod like this.
  2. Manual Slim
    Manual Slim Tele-Afflicted
    Up around the bend
    This sounds like a job for a Rat.
  3. dlew919
    dlew919 Poster Extraordinaire
    Sydney
    I try not to pile in, but I wonder if you got a trebl booster, like an LPB-1, though there are others, if that might work?
  4. StuartJames
    StuartJames TDPRI Member
    Take a look at the DOD Looking Glass, excels at low gain and I believe it was designed with a Vox in mind..
  5. RetroTeleRod
    RetroTeleRod Poster Extraordinaire
    Oklahoma, USA
    True. My Rat loves my AC15! The great thing about the Rat is that one pedal can cover a bluesy overdrive, harder distortion and on up into fuzz territory. It's amazing as a overdrive with the distortion knob down low. Any Vox owner really needs to try a one. I have the White Face Re-issue, but I have been told by some on this forum that the Turbo Rat is an even better match for the Vox.
    PastorJay and Sean Mac like this.
  6. schenkadere
    schenkadere Friend of Leo's
    NY
    Yikes. I think the LPB-1 ads a lot of dark color for a “linear” boost. The EHX Screaming Bird is a treble booster.
    dlew919 likes this.
  7. jrblue
    jrblue Tele-Afflicted
    Santa Barbara
    Boss SD1 or DS1 will give you a great alternative. And as others suggest, there are approx. 1,237,996 OD/DS variants, so you can try as many as you want. Honestly, with minor use of knobs, I can get just about anything from a TS or DS1. Steve Vai managed to get a lot out of the DS and he's got pretty good ears.
    Bowpickins and CaineIsCarter like this.
  8. dlew919
    Sydney
    It’s the only treble booster I own but I know there are some really good ones out there.
  9. Mincer
    Mincer Tele-Holic
    Tampa Bay Area
    Well it does, but it has a 3 band active EQ so you can tame it if you want. The Forza is the model that has no mid hump to speak of, and still has a 3 band active EQ.
    marcflores likes this.
  10. 8trackmind
    8trackmind Tele-Meister
    Memphis, TN
    It's probably been said already, but Tubescreamers and SD-1's are probably more useful with a Fender style amp. I also have the Timmy and Tumnus. I think either would work with a Vox but I would try the Timmy first. I'll also throw in the Way Huge Saucy box as another possibility.
  11. Charlodius
    Charlodius Tele-Meister
    Delaware
    Other than the Timmy, the Danelectro Cool Cat TO V1 is an excellent- and affordable- clone. I also find a Boss SD-1 works with middy amps because it doesn’t have the same eq hump to my ears.
  12. omahaaudio
    omahaaudio Friend of Leo's
    Omaha
    Nobels ODR-1 or a Timmy.
    Great pedals, not too expensive.
    marcflores and RetroTeleRod like this.
  13. 11 Gauge
    11 Gauge Doctor of Teleocity
    Near BWI Int'l
    The LPB-1 is most definitely not a treble booster. It's a full-range thing, and indeed does have a dark and gnarly sound, especially WRT a Rangemaster or Screaming Bird.
  14. 11 Gauge
    Near BWI Int'l
    IMO, it seems like a kludge, never mind any exorbitant cost. There are plenty of actual boosters that would probably work out much better, w/o any non-boost fluff in the circuit path (of which the KC has a lot!).
    It might be helpful for users to remember that Bill F. had the KC designed to make his Twin Reverb sound overdriven at modest volumes. So the original application was for the BF/SF Fenders, so it stands to reason that there would be a similar unpleasant effect when using a KC with a Vox AC15/30/etc., just maybe not as bad, or probably just different to, how a TS would sound.
    RetroTeleRod likes this.
  15. Bowpickins
    Bowpickins Tele-Meister
    Somewhere In TX
    I would recommend using a pedal like the Way Huge Green Rhino. I have one and it has an adjustable bass, mids, and tone knob for the highs. I can get some decent tube screamer like tones and it is a subtle overdrive, like the tube screamer. I use mine through a twin and deluxe, but not sure how it would work with a VOX. I would think the adjustable mids control would help, though. my specific model is the: Way Huge Green Rhino MkIV.
  16. paulblackford
    paulblackford Tele-Meister
    Cincinnati
    My normal gain pedal is a Zendrive, but I found that I didn't really like it for sounds with more top end (funk, etc...). I added a Mooer Blues Crab (Marshall Bluesbreaker clone), and it does a nice, bright gain that isn't too 'middy'. You can find them pretty cheap, and, at least you'll know if a blesbreaker tone is where you want to go.
  17. j5jarod777
    j5jarod777 Tele-Meister
    marysville
    FD2 Mosfet is a great pedal. Currently using F/M setting in Mosfet mode
  18. W.L.Weller
    W.L.Weller Tele-Holic
    Queens
    I'd like to pile on in favor of a germanium Rangemaster or other treble booster. I like this one
    http://ballseffects.com/boost/ballsmaster/
    but there are definitely other good ones, I just don't own those. I can also second (fifth?) the RAT.
    And if you're after lower-gain sounds, definitely try an OD250. Earthquaker makes the Grey Channel, DOD reissued it, but I have the Chicago Stompworks clone that I can absolutely vouch for.
  19. 11 Gauge
    Near BWI Int'l
    It's already been said, but I'll say it again, maybe slightly differently.
    The AC-series of amps are a different beast. Just go try out a bunch of different pedals with this specific amp.
    Who gives a crap what the actual good pedals are - let the chips fall where they may.
    JustABluesGuy and dlew919 like this.
  20. W.L.Weller
    Queens
    Oh also, I know this is "The Stomp Box" but have you tried plugging your guitar straight into the Top Boost channel and turning the knobs until it sounds good?
    PastorJay likes this.
