I suddenly don’t like my Tubescreamer anymore
Discussion in 'The Stomp Box' started by marcflores, Aug 5, 2019.
  1. EsquireBoy
    EsquireBoy Tele-Holic
    Paris, France
    TS and their mid hump are a perfect match with blackface Fenders that are quite mid scoopy.
    With an AC15 I would use a treble booster on the normal channel.
  2. Matthias
    Matthias Friend of Leo's Gold Supporter
    I had a DigiTech Bad Monkey for that TS sound... It sounded a bit congested on single coils. I recently got a Donner Blues Drive for a more transparent tone and it’s pretty good for the price if you want to experiment with some cheapies. Lowish gain and works well with my Blue Junior III and Micro Terror.
  3. srvbluezz
    srvbluezz Tele-Holic
    jersey
    I think it's the versatility that makes the klon circuit popular. It sounds good as a clean boost great overdrive and even pretty good as a distortion pedal.
  4. beninma
    beninma Friend of Leo's
    Massachusetts
    You're probably right. It seems like they all mix and match with different amps differently. For me the TS has that versatility with my amp whereas the Klone(s) I've tried (Soul Food & Tumnus) both produce the unpleasant double-mid-hump the OP is not happy about.
    Like I said I need to try my Tumnus again, I changed my guitar around recently and it might change my impression of the Klon.
    srvbluezz likes this.
  5. 3-Chord-Genius
    Winchester, VA
    ^ This.
    twangjeff, gkterry and RetroTeleRod like this.
  6. srvbluezz
    jersey
    I use it as clean boost for my tele and asat for the edge of breakup country tone. For humbuckers I'll use it as an overdrive into a dirty amp or stack of with my vox valvetone pedal(ts9 clone)
    The tumnus deluxe is even more versatile than the tumnus. Can't you just dial out the mid hump?
  7. Jerry_Mountains
    Jerry_Mountains Tele-Meister
    The City of Mountains
    It's very difficult to set a good tone with TS into a Vox. Try on the normal channel and play with the tone cut knob and the tone knob in the TS. A Vox has a strong and pronounced character.
    I recommend to try a RAT or a treble booster. With fuzzes I have had good sounds with the germanium ones, maybe 'coz they are warmer and the clipping its less abrupt.
    W.L.Weller and marcflores like this.
  8. bluesholyman
    bluesholyman Tele-Afflicted
    Greater Atlanta
    I have gone through a similar shift, but it was more that I didn't like the TS until I heard it through a Fender Bassman - most previous amps I had used were mids focused.
    For that Vox, its time to find another pedal. Some good suggestions here:
    marcflores and RetroTeleRod like this.
  9. Norris Vulcan
    Norris Vulcan Tele-Holic
    Somerset, UK,
    I like a Red Llama clone into my AC30.
    Really easy to build if you do a bit of DIY.
  10. LeicaBoss
    LeicaBoss Tele-Holic
    New Jersey
    Something like a Lovepedal Tchula, Zendrive or Timmy
  11. brookdalebill
    Austin, Tx
    I like the Durham Mucho Boosto.
  12. tubelectron
    tubelectron Tele-Holic
    France
    I had a vintage TS9 from the 80's, a TS10. I sold them very long ago because I found them sounding constipated, formatted.
    I rebuilt a clone pour dire d'en avoir un, modifying some parameters (notably opening the bass range, the possibilty for a very low level of drive) : it's better, yes... But I have better !
    I think I never really liked the TS pedal, in fact... :oops:
    -tbln
    EsquireBoy and Danny D like this.
  13. CalebAaron666
    CalebAaron666 Tele-Meister
    Portland, Maine
    Nocturne Detroit Casket Fluid Drive.
    It’s the best OD pedal ever!
    Drive your amp without changing your tone.
    It replaced my TS9, which was bugging me the same way yours is bugging you.
    marcflores likes this.
  14. Danny D
    Danny D TDPRI Member
    New Orleans born, now 40 miles west of Sacramento
    For a while I loved the combination of an OCD and my Tele. It worked well with the band I was in at the time.
  15. Bluego1
    Bluego1 Tele-Holic
    Spokane, Washington
    Excerpted from an article from an Orange amp tech (I use Orange). I’ve used my Joyo Vintage OD (808 clone) and Joyo Ultimate Drive (OCD clone) as described for the real things and it’s pretty spot on. Debating on getting a Pickle or clone thereof.
    Anyhow, I think the Vox has a similar “midrange bark” like the Orange guy mentions in the first attachment.
    RiverDog and srvbluezz like this.
  16. scelestus
    scelestus Tele-Meister
    Michigan
    I added a TC Electronic Spark Mini between my Tele and AC15. I didn't want any EQ and the Spark is just supposed to give you more of everything.
    It also works where I thought an EP Booster was too "smeared" for my tastes with Fender amps.
  17. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    I use a Blues Breaker with a lot of different amps. Low cut is less severe than a TS and it sweetens the highs nicely. Also like the SD-1 but the circuit is similat to a TS. Might be too close with a Vox.
  18. Wallaby
    Wallaby Tele-Meister Silver Supporter
    Midwest
    I am by no means "good" at dialing in distortion sounds, but I use a Timmy with my AC15HW and it has a lot of adjustment range.
    I've also heard the Hotcake is sort of the traditional partner for an AC15, but have no experience with it.
  19. Seds
    Seds TDPRI Member
    TheShop
    Germanium treble booster turned way up and roll the guitar volume off a little. The Timmy is also a great match for a Vox. The Crowther Hotcake was designed with a Vox in mind as well.
    W.L.Weller and gkterry like this.
  20. Hound Dog
    Hound Dog TDPRI Member
    Metropolitan Chicago area
    One more time. Get the Timmy. Really.
    marcflores, gkterry and RetroTeleRod like this.
