i should know this, peg to nut
Discussion in 'Tele-Technical' started by tedro, Dec 8, 2019.
  1. tedro
    tedro Tele-Afflicted
    7th Galaxy
    on a tele or strat neck, is where the string comes off the tuning peg supposed to be a straight line to and through the nut? or does the nut pull the string into line, as it sends it on and to the bridge?
    tia
  2. Fretting out
    Fretting out Tele-Afflicted
    Land of Mary
    From the tuning peg to the nut should have straight string pull, be straight from the peg to nut
    Although there should be a little angle from nut to peg caused by wrapping strings lower on the peg and the string tree ,which keeps the right amount of tension over the nut
    This is the best I can explain based on my understanding of the question
    I’m not sure about the nut to bridge part of the question
  3. moosie
    Western Connecticut
    Unlike a 3x3 headstock, the strings going over a Fender nut should only 'break' in the vertical plane, not the horizontal. In other words, saddle to tuning peg, the nut, and the tree(s) should be inline, and not pull the strings sideways.
  4. rolandson
    rolandson Tele-Holic Silver Supporter
    Cascadia
    The string should descend from the nut to the tuning peg.
    The only part of the nut that is in constant contact with the string should be the very leading edge.
    The nut slot should widen and angle down out the back, permitting the string to fall away to the peg.
  5. Peegoo
    Peegoo Tele-Holic
    We're not talking break-over angle here. This is looking 90 degrees from the plane of the headstock.
    Generally, yeah: the strings are in a straight line through the nut slots. However, if there's a slight angle, it's fine.
    Fretting out likes this.
  6. telemnemonics
    Straight string pull was a feature back then AFAIK.
    Since then we got things like the hockey stick and banana headstocks that showed it wasn't really all that important.
    But if it's supposed to be straight and is a little off that looks like a mistake not a design feature.
  7. TimTam
    TimTam Tele-Holic
    Melbourne
    Yep the strings should be straight-through. Fender got it right. The left-right string angling at the nut is a constant source of suspicion on 3x3 Gibsons whenever their tuning stability comes into question. How often it is guilty is open to question. But it leads to things like this ...
    Getting 2D nut slot profiling exactly right in one plane is hard enough, ie for straight-through. 3D slot profiling (for Gibson-style 3x3) is an extra level of difficulty.
  8. tedro
    7th Galaxy
    thanks all, i thought as much.
    i’ve got one that isn’t; and the nut pulls the strings from low (6th str) toward high (1st).
    ps. will glue hold it?
  9. Peegoo
    Peegoo Tele-Holic
    What do you mean? You want to slide the nut sideways in its slot?
    Before you do, look at the distance between each E string and the top playing surface of the frets (not the edge of the fingerboard). This is critical because you need about 1/8" of fret top on the outside of each E string. Any less than that, and you'll find yourself pulling the E strings off the frets' ends.
  10. tedro
    7th Galaxy
    what i was referring to is a strat neck that was made where the tuning peg holes apparently weren’t placed exactly so the string would cross the nut in a straight line; thus, the nut (not glued) gets pulled out and over upwards of the low E.
    —i was just checking and what i get from the replies here is: yes. it should be a straight line, ie, holes must drilled accordingly.
  11. Peegoo
    Peegoo Tele-Holic
    Yes, it should be a straight line. But if it's off by a bit, it's not a problem.
