I've had a 2011 Melody Maker Explorer for a number of years now (got it in a trade for a MIK SG copy, won that one!). I didn't care for the hot pickup, so I put a Dimarzio medium output DP155 F-spaced in a while ago (these Gibson guitars strangely need F-spaced). Love the sound but assumed, from much internet banter, that the cheap non-compensated angled bridge was a weak link and "had" to be replaced. Everybody does it with those, right?
So, I picked up a Wilkenson bridge, non-adjustable individual strings except for the moveable D/G section and put on new GHS 10-52 TNT boomers. I like those heavy low strings/light upper string sets in a number of my guitars. Plus, they seem to work well with guitars that are one pickup in the bridge position, such as this one. Tried over the last year to get this adjusted well and failed at every turn. Last attempt recently resulted in a sitar like high E string sound. Plus, using the stock Gibson bridge posts, the Wilkenson had way too much forward "lean" to it. I am not about to try to pull the inserts and use the ones that came with the bridge. So, I broke down and said, "screw this!".
I yanked the bridge and strings, put the original bridge on and put on a set of 10-46 strings. I only put on both E strings (easier to set gross intonation) and after that adjusted height and added the other strings. I was curious how off the other four strings were and was shocked. Two were right on and two were, at most, one or two cents off. WTH!! Two days later with broken in strings it's the same.
It sounds excellent and in tune up the neck, so I'm inclined to think the tuner isn't an issue. So, did I get extremely lucky or what?
