I realize wiring a 3 way switch should be easy but....
Discussion in 'Tele-Technical' started by wanderingscot, Jan 13, 2019.
  1. wanderingscot
    wanderingscot Tele-Meister
    Tyler, TX
    I'm stuck again!
    Seems my old 3 way that I was going to use looks backwards(top lugs shifted left vs right)from the wiring diagram I'm trying to use. (Seems every diagram I see has the lugs shifted the other way.)
    Question 1.... Can I use this switch to follow this diagram?
    Question 2....Is my switch upside down? In the pics the switch is in bridge position.
    I know it should be easy, but I'm confused!
    Here's some pics from both sides and the wiring diagram I was hoping to follow.
  2. 24 track
    kamloops bc
    the diagram is correct and should work fine , for your own edification ( before you solder ) take out the switch and look at how the traces contact when you move the switch,it will give you a clearer picture of what you are trying to accomplish,
    if you are confused reverse the switch to match the diagram
    awasson likes this.
  3. rolloman
    rolloman Tele-Holic
    SC
    Yeah the look of it shifted is not a problem.
    wanderingscot likes this.
  4. moosie
    on the roof
    Reversing the switch won't help. Both are symmetrical, and not the same. As recommended, look at the action of the switch, or use a meter, to find the one that connects to each of the others on each side. In my experience, these switches are often drawn wrong, but generally correct. Meaning, the commons are in the right locations. So, you're probably good, but an eyeball check can confirm.
    24 track and wanderingscot like this.
  5. moosie
    on the roof
    Regarding upside down, place your switch tip in bridge position. Watch the wiper rotate on the central axis, to the other side of the switch, lugs nearest the headstock.
  6. jfgesquire
    jfgesquire Tele-Meister
    Lake View
    It doesn't matter if the furthest forward tab is on the left or the right. Just as long as you number the tabs the same and connect the wires to the correct numbered tab.
    Unfortunately the switches that are reversed from the drawings or online pictures won't look exactly the same but they will work exactly the same.
    Sent from my LG-H830 using Tapatalk
  7. 24 track
    kamloops bc
    I said that so he ( the op ) would have the same perspective , then I reversed the photo and it is the same as the diagram , so the op should have no issue to wire according to the schematic.
    just amatter of perspective!
  8. sjtalon
    sjtalon Doctor of Teleocity
    Upper Peninsula of Michigan
  9. wanderingscot
    Tyler, TX
    Thanks everybody. I really appreciate it!
  10. wanderingscot
    Tyler, TX
    One more question. I've also got an old seymour duncan STK-T3b Vintage Stack bridge pu. A stacked hum bucker. Could I use this instead of the Fender MIJ 62 reissue I was going to put in the bridge?
  11. Mincer
    Mincer Tele-Meister
    Tampa Bay Area
    It should fit, and it is actually a great choice- very quiet, too!
  12. Mdmoore255
    Mdmoore255 TDPRI Member
    Georgia
    I had this same confusing situation just last night. Even though the symmetry was off, I went ahead and soldered keeping the sides the same matching the pots in the diagram. It worked perfectly. Don’t sweat it.
    24 track likes this.
