I Played The Fender Tone Master Amps Today
Discussion in 'Bad Dog Cafe' started by Otis Fine, Sep 10, 2019.
  1. TeleTex82
    TeleTex82 Friend of Leo's
    Out there
    I think I've made up my mind to sell my blues cube tone capsules to fund a TMTR. I'd have the best of both worlds, tweed and blackface!
    DekeDog likes this.
  2. Ironwolf
    Ironwolf Poster Extraordinaire Gold Supporter
    Boise, Idaho
    I can make a new report on the Tone Master Twin Reverb's sound (or tone, if you prefer) when running at the .5 watt level.
    I had been using the #2 input as I had on my Blues Deluxe to help control the volume for in home use. On a whim, I switched to the #1 input (which is supposed to be 5 or 6 dB louder) and it made all the difference in the world. I can now get a decent, convincing sound and volume with out having to push the amp up into breakup. Don't misunderstand, neither it on it's own or working with the Origin 50 half stack in it's 1/2 watt mode is enough air moved to make you "feel" the amp (I'm talking about the vibratory chest and gut punch of a properly breathing amp) but, the proper "tone" is definitely there. I can now run the amps together wet/dry at a non-window shaking level and have them sounding, not just pleasant, but right and usable.
    Leave the settings the same but flip the amp switches to 5 watts and you get the same sound with a pleasing loudness that I love and can use but, admittedly, may be two loud for most to use at home (unless they have no family or close neighbors).
    amorica and TeleTex82 like this.
  3. harry ramsden
    harry ramsden NEW MEMBER!
    uk
    In my experience people who A/B valve/tube and ss/modeller amps don't listen for the same things that I do. Sometimes it takes a while to realise what's missing, or what can't be changed. If a lot of people are happy with a certain ss/modeller amp used in a particular way, then it's a good indication it will be ok for those people and that use it in that way. It doesn't mean it will emulate well for all situations and uses. I'm definitely attracted to the low weight, but I've had mixed results with modellers, often because the aims of those doing the modelling have been different to mine. It's often resulted in a 'snapshot' of one of the real amp's configurations, but not the whole range. Of course the real amps and similar amp types vary, so it's not surprising a single 'model' has a lot to manage. When I get round to trying one I'll try and check for things I specifically look for as well as general capability. I've had better results recently with s/s emulators rather than modellers. They seem to have a degree of complexity to their sound that the modellers don't. OTOH some folks don't want complexity and prefer the snapshot sound which doesn't vary much. I was once that person and it bugged me that the sound varied too much when I was doing stuff on the guitar or its controls. Now I'm more in the opposite direction, not that I wan't ramdom changes, but do look for stuff you can vary predictably guitar and control variety.
    Bones and DekeDog like this.
  4. wharf_rat
    wharf_rat TDPRI Member
    Flint, MI
    For me the main sell would be weight, or the lack of rather. I haven't played one yet but from what I have read it could give a 70 pound Fender Twin a run for it's money. For players who are on the move these TM could be a nice grab.
  5. DekeDog
    DekeDog Tele-Holic
    Carolina
    This thread has cured me of my desire to check out those Blues Cubes. I expect the prices on both the Tone Master and the Blues Cubes are worth it, but it does concern me that an S/S modeling amp should be priced that high, when I've got a tube amp for only slightly more cost that I'm very happy with and an S/S amp that does what I want. Maybe I'll control my AAS until the price drops and the kinks get worked out.
  6. TeleTex82
    Out there
    Don't get me wrong, the Blues Cubes are great amps. I am very happy with mine.
  7. deytookerjaabs
    deytookerjaabs Friend of Leo's
    Nashville
    Yep, the best bench testing for any signal processor:
    Say, you've a "JTM45" patch on your Kemper or whatever.
    Get as close to a real example JTM45 next to it with a guitar tone mostly clean to edge of breakup.
    Now, take a slightly different guitar, say a Les Paul to a 335 and listen for the variation. Optimally the real world variation between the two guitars will come through in your processor as much as in real life. There's a difference between "sounds good" versus "acts the part." This is before even sweeping through the amps/instruments control ranges, just the basics.
    It's those different input/output reactions in the real world that will define a processor's sound. You see it a lot with modeling reverb units. You plug in a compressed Tele and think "man they nailed it next to this plate reverb box" but then you plug in the Gretsch w/filtertrons and the digital unit will be way too balanced/warm compared to the real box.
    Again, the biggest challenge isn't creating a specific model of a certain recorded sound, per se, it's getting a modeling unit to act like the real thing regardless of the input signal.
    pugnax and ndcaster like this.
  8. 2HBStrat
    2HBStrat Tele-Afflicted
    Four Rivers Area of Middle America
    Is the Twin really 200 watts?
  9. Ironwolf
    Boise, Idaho
    Yes it is 200 watts.
  10. Otis Fine
    Otis Fine Tele-Afflicted Silver Supporter
    Chicago, Illinois
    However they did it, it's my understanding that they have made this amp capable of being every bit as loud as an 85 watt all tube Twin Reverb. However many solid state watts that is, I don't know.
  11. Dan Spiffy Neuman
    Dan Spiffy Neuman Tele-Holic
    Madison, WI
    I never cared for modeling. I dont want one amp that sounds like 457340573408573 amps, I want it to sound like itself. However I've always wanted a lightweight Twin, preferably solid state. I'm excited to try these.
  12. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    Newsflash: at NAMM 2020, the Twin Reverb (you know, with tubes) will have a switch that lets you choose between tweed and blackface tones. Expect the next version of the Tone Master to follow suit. :p
  13. 2HBStrat
    That's interesting...
  14. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    Do you think this will be something other than a 'raw switch' that drops the bass & mid pots out of the circuit?
  15. BigDaddyLH
    I'm thinking pixie dust ;)
    I'm pointing out that what the Tone Master can and should do is arbitrary -- it's what players think is appropriate and that can be a moving target.
    Mexitele Blues likes this.
  16. Mexitele Blues
    Westminster, CO
    Haha, wow. You cast, I bite.
  17. BigDaddyLH
    Tweed/Blackface in one tube combo is an awesome package. Some other amp makers have done it, but is there any Fender that does that?
  18. Mexitele Blues
    Westminster, CO
    It's my understanding that the '68 Custom DR & VR purport to have a Bassman-style tone stack on the Normal channel, but the preamp topography is still that of a Black/Silverface.
  19. BigDaddyLH
    yeah, no ceegar there.
  20. unixfish
    unixfish Doctor of Teleocity Silver Supporter
    Northeast Ohio, USA
    Agree. I would never expect a modeller to sound EXACTLY like a tube amp. For that matter, take three blackface DRs, three silverface DRs, and three DRRIs. Guess what? You will have nine distinct sounds, although the DRRI triplet will be very close. Upgrade a speaker? Different sound. Swap tubes? Different sound. Swap resistors / caps? Different sound. And on and on it goes.
    So what is modelling aiming for?
    I would expect the engineers to have a "range of sounds" that are what people classify as a Deluxe Reverb. There is no one DR sound. If a modeller is in that range, then what the heck, call it a DR patch / DR TM and call it a day.
    My guess is we could assemble 100 DRs in various vintages and with various speakers, and we could not agree which one represents "the" DR sound. I am thinking that DR sound is an "in the ballpark of" range, and many have said he TM line is in that ballpark.
    Yeah yeah yeah dynamics and pick attack and feel and sensitivity and compression and sag and bloom and all that. But what is the proper value of those from the 100 vintage DRs we stacked up? How do you measure "feel"?
    I think Fender is saying "If it's close enough, it is". Even the 65 DRRI vs 68 CDR are different sounds, but "close enough" that they share the DR architecture. Even the 65 DRRI patch on my Mustang III is in that same ballpark.
    "It it's close enough, then it is."
