I needed a 4 foot pipe...
Discussion in 'Bad Dog Cafe' started by Buckocaster51, Oct 8, 2019.
  1. Wally
    Sometimes a penetrating oil is useful. I grew up with a product called Knocker Loose. WD40 will probably have the same effect. Spray and let it sit a while.
  2. Guitarzan
    Guitarzan Poster Extraordinaire
    Hotlanta, GA
    Et tu, Brutus?
    Buckocaster51 likes this.
  3. getbent
    getbent Telefied Silver Supporter
    San Benito County, California
    More is often better. Way to go Buck!
  4. Guitarzan
    Hotlanta, GA
    Electric induction heaters exist that can be use if you do not have a rosebud.
  5. Stubee
    Stubee Doctor of Teleocity Gold Supporter
    Mid-Michigan
    I’ve used both heat and a 4’ breaker bar to get a bent bush hog blade off. It’s a great feeling when ya finally get it loose.
    I have to use a breaker bar to tighten the chains down when trailering my tractor. Problem there is ya better not be in the path of that thing if it slips outta your hand. I should probably get some ratchet binders but my old “takes a breaker bar” binders are paid for!
    drf64 and Buckocaster51 like this.
  6. Viejo
    Viejo Tele-Afflicted Silver Supporter
    Central IL
    Tell the truth ,you trash talked that bolt after you got it off didn't you
    Bones likes this.
