I need some schooling on pickup height.
Discussion in 'Just Pickups' started by Digiplay, Feb 19, 2020.
  1. Digiplay
    Digiplay Tele-Holic
    Birmingham, Alabama
    I know one's ear is the bottom line, but I have several questions about pickup height.
    Does the closer a pickup is to the strings make a guitar brighter in tone?
    Does the closer a pickup is to the strings make no difference in tone, and simply makes the guitar louder?
    Is there a limit to how close to the strings a pickup can be?
    If one wanted a darker tone, does raising just the bass side/ lowering the treble side height accomplish that?
  2. schmee
    Generally I say the closer the brighter.
    I find too close and I end up "cliking" the pole with strings.
    Raising the bass side gives more low end in the mix. Darker to me means less clear tone, not necessarily more low EQ.
    Maybe it's just me...
    Some pickups are generally said to sound better further away, like P90's...
  3. stefanhotrod
    stefanhotrod Tele-Holic
    germany
    But too close isn‘t a good idea- the magnets pull on your strings if they‘re too close. You‘ll also loose definition, dynamic response and tonal complexity. Rule of thumb on Vintage style pkups: 6/64” bass side, 5/64” treble side.
    That‘s a good basis for your finetuning.
  4. Danb541
    Danb541 Tele-Afflicted
    Oregon
    Does the closer a pickup is to the strings make a guitar brighter in tone? Yes and louder but too close is bad. The pull of the magnets can stop the strings from vibrating.
    Does the closer a pickup is to the strings make no difference in tone, and simply makes the guitar louder? Same answer, typically brighter and louder.
    Is there a limit to how close to the strings a pickup can be? Well... they cant be touching the strings so I suppose that's the limit. Too close doesn't sound good to me.
    If one wanted a darker tone, does raising just the bass side/ lowering the treble side height accomplish that? I suppose that could work, I would try lowering the entire pickup. On my fender guitars, I usually have the bass side of the pickup a little lower than the treble side.
    radiocaster and gimmeatele like this.
  5. EsquireBoy
    EsquireBoy Tele-Afflicted
    Paris, France
    IME, closer to the strings gives more compression, so the overall volume is louder but the perceived volume can sometimes be lower since you have less dynamic peaks when hitting the strings. Of course depends of many other factors: clean or dirty, amp’s headroom, the way you play, etc.
  6. AlbertoMilanese
    AlbertoMilanese Tele-Meister
    Bavaria
    If you're able to fit a finger between pickup and strings, you're basically set
  7. LOSTVENTURE
    LOSTVENTURE Tele-Afflicted
    Charlotte, NC
    The closer the brighter theory is good for single coils but necessarily for humbuckers or overwound single coils (Mosrite is a great example).
    Since you know how to change the height, everything else is going to depend on your personal thinking as to what you are looking for.
  8. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    This is from Fender Support
    WingedWords likes this.
  9. WingedWords
    WingedWords Tele-Afflicted
    UK Europe.
    Deleted.
    I just duplicated Gardo's post.
  10. 1300 E Valencia
    Fullerton CA
    How the pickup is constructed can make a big difference in how far away you want the strings from the pickup for optimum sound.
    Fender-style single coils are very different from Gibson-style humbucking pickups. Mini-humbuckers, stacked single-coils, etc., are all different.
    It's usually best for beginners to start with the manufacturer's specs, then tweak until it sounds horrible, then get 1,000 completely varying and often opposing opinions on the interwebs, then set it back to factory recommendations.
  11. 65 Champ Amp
    65 Champ Amp Tele-Afflicted
    Illinois-Wisconsin line
    The sweet spot is usually lower than you think.
  12. rigatele
    rigatele Tele-Afflicted
    It does make a difference, but not nearly as much difference as some people believe.
    8trackmind likes this.
  13. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    And if low sounds good, like some vintage (low output) pups
    sound great that way, don't be afraid you're getting cheated because of a little power loss. That's what an amp is for.
    Also, at times one can tilt a pup to gain or lessen treble or bass, one way or the other, depending on what sounds good to YOUR ears. So other that for looks, a pup doesn't HAVE to be flat !
    Pup height can make of break ANY pickup and some may be getting cheated on best tone because they don't think to spend the time adjusting them, or go by what someone else says or published specs.
    Specs are a good START POINT, but a good half hour with a screwdriver is time well spent.
    I turn a screw one turn at a time from a given start point, and write (count) turns moving both up and down, so you can go back to the best spot.
    Experiment.
    I always say; YOUR geetar, YOUR ears.
    Happy pickin'
  14. Chunkocaster
    In space with Ziggy
    I think it's best to forget about measurements and just plug in and set the amp to whatever volume you use and play. Adjust the height up or down according to what you hear.
  15. 3-Chord-Genius
    Winchester, VA
    Also note that active pickups like EMG are built with relatively weak magnets, and you can raise them pretty much as close to the strings as you'd like without the negative effect of magnetic pull.
  16. Rob DiStefano
    Rob DiStefano Doctor of Teleocity Vendor Member
    NJ via TX
    yes, just use yer ears - the best measuring tools for sound. that and a screwdriver. you can set the passive pickup tops as close the strings as possible and work down from there in small increments, say one turn each of the height screws. set up high, more balls and output ... set down low, more acoustic-like and lowered output. trust yer ears, not some ruler or caliper. each guitar is an "experiment of one", each of us need to figure out what sounds best because most everything about most any guitar is subjective and one size won't fit all.
    "brightness" is all about the design of a passive pickup. each single coil is designed to produce a specific amount of treble. treble can Never be added to a passive pickup, only removed. a bridge pickup senses the low string excursion area and is more conducive to "twang" than the neck position, as expected.
  17. kafka
    kafka Tele-Afflicted
    Potomac, MD
    There may be a more scientific or principled way of doing it, but I just use my ears. My pickups often end up quite low. One of the properties that I think I'm responding to is how much drag is placed on the string.
    Without getting into whether it's brighter, or darker, or whatever, because I haven't really articulated it to myself, I find that if the pickup is too close, the string sounds more constrained. And if I get the pickup too far away, it sounds weak. Somewhere in the middle is an optimum.
    But, while this sounds like an objective statement, it's not, because the main governing factor is simply how I feel about the sound. I will say that in general, I don't like the pickup to be too close.
    There's only one situation where a setup can be objectively 'wrong'. It is sometimes possible get a false harmonic or some tuning issues with a particularly strong set of magnets set particularly close to a set of strings. In general, though, you kind of need to put some effort into creating this condition. It's a possibility, but pretty uncommon with most normal setups.
  18. uriah1
    Around
    Yea, certain pickups you may need more and neck vs bridge also.
    I generally use the (nickel/bass-dime/treb) method for electrics..
    except p90s which are whacked with those pole pieces..lol
  19. Anita Bonghit
    Anita Bonghit Tele-Meister
    Colorado
    I've always used 2 nickels sliding between pickup top and the strings while fretting the last fret. It may not be booteek but will pretty much put you right there. Fine tune by ear.
  20. stormsedge
    stormsedge Friend of Leo's Gold Supporter
    Tennessee, USA
    What a timely post! Before seeing this thread this morning, I'd printed the above mentioned Fender paper (last night) and set my Nashville Deluxe to the Texas Special specs...what a difference! I've long thought this guitar wasn't right (had it for only ~8 years), but bought it from a "guitar guy" so have not really messed with it. Apparently his Telecaster work is suspect. In any event, I found all the pups incredibly low (duh...may be why it doesn't sound like a Tele and more like a whispering auntie...not all me), and raised them all to 8/64 and 6/64. I may raise them a little more, but for now I'm enjoying my new guitar.
    Jakedog and preactor like this.
