I need help with a wiring diagram please.
Discussion in 'Tele-Technical' started by marianopodesta, Oct 26, 2020.
  1. marianopodesta
    marianopodesta TDPRI Member
    Argentina
    Hey sjtalon I’ve got another question, why on the humbucker you Drew 5 wires getting of from it? As I’ve been seen the humbuckers usually come with 4 wires, can you explain me how do I connect another wire to get the fifth one?
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    Four coil wires, and sometimes a braided, or bare wire that grounds the metal cover that then acts as a shield.
    My yellow there was a poor choice :confused:.
    So you see that is going to the back of a pot can.
  3. marianopodesta
    Argentina
    Ohhh thanks :) know I understand
  4. sjtalon
    or to ground a baseplate if it had no cover
  5. marianopodesta
    Argentina
    Ok thanks for the explaining
  6. sjtalon
    So with normal wiring of a humbucker, you just have a hot (positive) lead, that goes to the switch, and then the other COIL lead (negative) gets grounded, so usually the bare just goes with the coil ground lead, soldered together.
    If you notice in that picture, the black is with that bare wire for that grounding.
    Now with you doing the SERIES, the hb COIL negative (normally grounded), has to go to the switch now, (BLUE WIRE) because in your selector switch position THREE, it will go in series with the bridge pickup.
  7. marianopodesta
    Argentina
    Great! Thanks. Last weak I received the hardware parts like the wires, control plate, Jack, pots, etc. next week I’ll buy at least the bridge pickup, maybe the neck too, or maybe the next moth.
    thanks por the explaining.
  8. sjtalon
  9. sjtalon
    Sounds good.
    My pleasure.
  10. marianopodesta
    Argentina
    Hey sjtalon I’ve got anothe question, look I bought the 4 way switch and I don’t know in what direction I should put it. I’ll send 2 pictures with a number 1 and a number 2, please answer me in what way I should put it.
  11. sjtalon
    Either way, doesn't matter.
    See my diagram, any way you put it in the control plate, the STAGGER of the lugs, top and bottom, are the same.
  12. marianopodesta
    Argentina
    Ha
    hahahhaa okay thanks
