I need help on what to pick...
Discussion in 'Worship Service Players' started by Telemarcster, May 11, 2017.
  1. Telemarcster
    Telemarcster TDPRI Member
    France
    my current gear setup is as follows.
    - polytune
    - xotic ep booster
    - jhs morning glory
    - ehx od glove
    - boss dd-20
    - boss rv-6
    Im looking at buying some new gear, i need to buy better power as my one spot isnt coping with delay and the morning glory on there are sound issues.
    should i buy the sub 'n up, an ernie ball vp jr, a pro co rat (which im not so sure on but seems like a standard for worship) or some sort of compressor, i only should really be buying one...
    running a telecaster into the pedals in to a vox ac15.
    thanks.
  2. dpandri
    dpandri TDPRI Member
    Jakarta, Indonesia
    Looking at your current gears, i believe a compressor will be a better choice.
    The others can wait, especially the proco since you've got 3 od/boost type pedal that you can stack together for higher gain stuff.
    I never knew how much a compressor helps in my sound until i got one recently. If you are going for the "common" worship guitar sound, go and get a decent compressor!
    Just my 2cents.
  3. callasabra
    callasabra Tele-Afflicted
    I would second a compressor, especially if you are playing modern stuff. You are missing a chorus pedal, I use chorus half the time I play. Unless or are dissatisfied with your current OD options I would not put the rat high on the list. Not that there is anything wrong with that pedal.
  4. Telemarcster
    France
    And what compressors then would you recommend...
    I have a budget of about £100 so roughly $130
    thanks
  5. callasabra
    I have used the DOD FX80B and been satisfied. You can pick these up well under your price range.
    I currently use the compressor sim on my Line6 PODX3LIVE board.I keep my Comp on most of the time when playing modern stuff. I will kick it off occasionally.
    The MXR Dyna Comp, wampler Ego and Xotic SP compressor are OTA (Operational Transconductance Amplifier) and are sometimes referred to as 'organic'. Unless you wanted a vintage sound I would by a new/newer pedal because these older models are known to 'color sound' or 'suck tone'. Newer models have improved on this.
    Then there is Keeley. studio grade, different approach. I have known very few people use these, but those that do seem to praise them. I have no experience so I don't know if it is a matter of cork sniffing or absolute quality. You might be able to grab a used one in your price range.
    You might consider the Route 66 Trutone since you initially asked about the Proco Rat. The Trutone is Overdrive & Compression. You might even find the Trutone will replace one of your existing pedals because you some overlap with EP Booster, Morning Glory and EHX Glove.
    I have never used the Glove before but I understand it has some interesting qualities.
    You also might check out the CHATMODS signa comp (it is/was on Nigel Hendroff's board, Hillsong) I have no experience with it. I think this is boutique but within your price range and are available on amazon/ebay/sweetwater I think.
    If I were in the market like you, I would find a store and start with the Trutone. If you want to roll the dice, buy used on Reverb/ebay if you are not satisfied sell it.
    CAAD8N8 likes this.
  6. CapnCrunch
    CapnCrunch Friend of Leo's
    Washington, USA
    If you can find a comp that allows you to blend the compressed signal with the dry signal, it is well worth an increase in price. I use an Empress compressor and it is the best I've used or tried, but it is around $200 used. Wampler makes a good compressor with a blend also. I just checked Reverb, and the Ego compressor from Wampler can be had used for around $135. It's got the blend feature and sounds and feels good.
    CAAD8N8 likes this.
  7. SngleCoil
    SngleCoil Tele-Holic
    Charlotte, NC
    Agree on the compressor and definitely recommend one with a parallel/blend option. Look for a used Barber Tone Press as an alternative to the Wampler Ego. I've seen them in the $90-$130 range on Reverb.
  8. mRtINY
    mRtINY Tele-Afflicted
    Orygun
    Modulation. You need modulation....
  9. Telemarcster
    France
    Still not convinced on the compressor....
    Ive never played something and thought a compressor would be really good here and i already use my ep booster as an always on.
    What you guys think about the tc electronic forcefield compressor?
    Just not sure...
  10. Telemarcster
    France
    But yet again maybe its a secret ingredient that when i get one itll make a huge difference..
    callasabra likes this.
  11. callasabra
    I have no experience with the forcefield, but TC Electronics makes nice pedals. I never used a comp until I got my 7 string, then I saw a need for a comp. Then once I had one and used it I found it useful for my 6 string as well. I don't have an ep booster, but it is on my list. My understanding of the ep booster though would yield different results than a compressor. I invite correction with this statement. I believe most recordings today employ compression to some degree, some genres more than others. but I find modern P&W music uses it quite a bit.
    You are missing modulation as other posts mention so something in that flavor.
  12. dpandri
    Jakarta, Indonesia
    imho a compressor is the secret sauce that I've been missing to easily dial-in the contemporary worship guitar sound. More so with the crisp clean tone that you have been hearing in recent CCM.
    The EP booster is more like a pre-amp/tone buffer/booster fx, it is not the same as how a compressor work, that being said you could use a compressor to do what EP booster could, but not the other way round.
    I will agree with the others that the next in line should be modulation of some sort.
  13. Telemarcster
    France
    So if i went for a compressor what do you guys think of:
    Dr J aerolite compressor or a jhs modded dyna comp with the ross circuit in there? The problem for me is always shipping from reverb as its always an extra 20
  14. blille
    blille Tele-Afflicted
    Bay Area - California, USA
    mRtINY aka "the modulation evangelizer" :D
    I'll second that.
    I do love a good comp though.
    mRtINY likes this.
  15. asatattack
    asatattack TDPRI Member
    Edmonton, Alberta, Canada
    I own a Keeley Compressor and a Retrosonic Compressor, which is a reproduction of a gray Ross compressor. They are both both great! I used to own a Proco Rat, really liked that but I gave it to a friend. Own or have owned some TC Electronic stuff, can't go wrong with them.
  16. 79Blackie
    79Blackie TDPRI Member
    Bakersfield
    I have a Wampler Ego Compressor. It replaced a Boss CS-3.
    I never liked the CS-3 because it would give me the sustain I was seeking but kill the initial note attack. Backing off the compression gave the desired note attack but then no sustain. I used it sparingly only when needed.
    It's not just the CS-3. Every compressor I had ever tried gave me unwanted side effects. I wanted a compressor which would give me the compression and sustain of a cranked dirt peddle, without the heavy metal sound.
    I can't say enough about the Ego. I set all the knobs at 12:00 except the tone which is at 1:30. I adjust the volume to match the level of the uncompressed signal.
    Most people I demo it for don't know there's any effect on. That's a very natural sound. They can't tell it was there until you turn it off.
    I often take the compressed signal and run it into a dirt peddle with very little gain. It sustains and even roars like it has huge gain, but with a kinder, gentler sound. Very useful for worship songs.
    Bottom line: Don't mess with a compressor without a blend knob.
  17. CAAD8N8
    CAAD8N8 Tele-Holic
    Ohio
    Tc hypergravity
  18. h2odog
    h2odog Tele-Meister
    The Dalles, Oregon
    For compressor I would second the TC Electronic Hypergravity as an affordable option. I have an older JHS Pulp n Peel that I use all the time. they tend to be more expensive though you might find a used one for a decent price.
  19. callasabra
