Yes IN FACT (and by 13 lbs difference)In fact?
In my basement with my shifty playing and my cheap guitars, any difference I hear doesn't really matter
I see someone is going through the Godzilla/Mothra phase.Break your back?
Both of my tube amps (Marshall 1974x and Tweed deluxe) are featherweight , in fact lighter than your modeling amps.
View attachment 1034493 View attachment 1034494
I see someone is going through the Godzilla/Mothra phase.![]()
One of the great marketing scams in MI equipment history was convincing the public that clipping a 12AX7 was "tube sound", and you didn't need all those hot, heavy, expensive output tubes and their associated circuitry. You do, though.I also had an ADA MP-1 which was the rackmount tube preamp of the late-80's into the early 90's. Anyone who was anyone had one of those. I plugged that MP-1 into the Fender Frontman clean channel, A/B'd back and forth between that and the Fender's distortion channel (with the MP-1 bypassed), and with a little gain and EQ tweaking, both sounded identical. The LED distortion of the amp sounded exactly the same as the MP-1.
Why do you care?Seriously, all this muh-t00bs-über-alles sniffery / snobbery has got to go. It had its time and that time's up.
In my applications though I can tell a difference, and it's usually pretty obvious
And then that clipping 12AX7 sound launched a thousand pedals with (solid state) diodes to clip without the pesky tube in there at all. Virtually an entire industry evolved around providing every possible minute variation in diode clipping.One of the great marketing scams in MI equipment history was convincing the public that clipping a 12AX7 was "tube sound", and you didn't need all those hot, heavy, expensive output tubes and their associated circuitry. You do, though.
Hey, good for ya. But it's the lightest I've got regardless.Yes IN FACT
'cuz it passes the time & makes the popcorn tastierWhy do you care?
The black SUV's are on their way . . . . .I convinced myself I can tell a tube preamp, especially the way I tend to dial my gear. But I cannot tell if an amp has a tube power section unless it is completely blowing out, all knobs a row of dimes.
Being fully transparent, I love my Plexi and that’s that but I hardly ever use it. I have spent a lot of money on preamps and devices to try to get the sound I like from my combo so I can not be as loud so my screeching sounds don’t disrupt bird migrations.
I know full well I can’t tell the amp type on any recording. I admit it.
You should probably have your hearing checked.I thought I could, and spent years in a "tube only" phase. But this past week or so, I've come to the realization that it was all in my mind. Now, I can tell the difference between a good and a bad amplifier, regardless of technology. And I have owned bad tube amps and bad solid state amps; however, as far as tube "warmth", "dynamics", etc., I simply don't hear it. The seeds of doubt began a few years ago when I had a Fender Frontman with a built-in LED distortion circuit. I also had an ADA MP-1 which was the rackmount tube preamp of the late-80's into the early 90's. Anyone who was anyone had one of those. I plugged that MP-1 into the Fender Frontman clean channel, A/B'd back and forth between that and the Fender's distortion channel (with the MP-1 bypassed), and with a little gain and EQ tweaking, both sounded identical. The LED distortion of the amp sounded exactly the same as the MP-1.
"Dynamics" is one element that tube amplifiers supposedly excel in (responsiveness to picking), but every single amp I've played through, tube or solid state, would respond dynamically if the gain knob was set right. "Warmth"? I've been fooled plenty of times by what I thought was a tube amp that turned out to be solid state. I thought I got a fantastic deal on a Hughes & Kettner tube rack preamp when I was stationed in Germany. The price was great for what (I though) I was getting based on the tone I heard in the store. I opened it up to see how many 12AX7's were in there and all I saw was a circuit board...
Of course, there are things like tube rectifier "sag" that is exclusive to tube amps, and that is something I've never really had a thing for, though I understand some people love it. But as far as tone itself and dynamics, no - I can't hear the difference. Odd and even-order harmonics? Can't hear the difference.
I'm open to the possibility that if I sat down with one good example of each, and spent some time going back and forth, there might be something I'd notice, but that "something" just might be the difference between two different amplifiers anyway.
