i have no idea...
Discussion in 'Tele Home Depot' started by mickeydean, Jun 14, 2014.
  1. mickeydean
    mickeydean Friend of Leo's
    millersville
    i have a danelectro with a broken neck. would i be able to put a tele neck on it?
  2. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    The most important piece of info you'd need to know is the scale length of the current neck vs. the scale length of the neck you want to put on. Measure the distance from the front edge of the nut (the side where the strings enter) to the middle of the 12th fret. Double that distance and you have the scale length.
  3. guitarbuilder
    Why not fix the Dano neck?
  4. Outcaster
    Outcaster Tele-Holic
    The Mountains of Western North Carolina
    Most, maybe all standard Dano's have a 25 inch scale length and little adjustment for intonation at the bridge so it's likely not a bolt on mod. I'd say fix the neck if you can, buy a used one (eBay or CL) or you could have a custom neck made. If you go the last route just make sure the builder knows what you're doing.
    What model Dano is it and how exactly is the neck broken?
