I had a crazy idea the other day..
Discussion in 'Acoustic Heaven' started by el cheapo, Aug 27, 2014.
  1. el cheapo
    el cheapo Tele-Afflicted
    Southcentral Pa
    I had a crazy idea the other day. Why not play my little Martin acoustic through a Bandit? I have an old Peavey KB1 that sounds good,
    but I was interested in how the Martin would sound with a little reverb. So, I hooked her up to my 50 watt Bandit.
    I plugged into the low gain channel and after a little tweaking it sounds pretty darned good! Reverb seems to work well with fingerpicking or strumming. A little chorus sounds really good with fingerpicking.
    Anybody tried compression or delay with an acoustic?
  2. repeatofender
    repeatofender Tele-Afflicted
    Carrollton, TX
    I don't know...
    pretty crazy.:cool:
    If it sounds good to you, very cool. It can be hard to find a good amp for accoustic.
  3. 985plowboy
    985plowboy Friend of Leo's
    South Louisiana
    Go for it
  4. el cheapo
    Southcentral Pa
    I probably should have mentioned, I'm using a K&K pure mini pickup and a Behringer ADI 21. I also have an LR Baggs Para DI, but I tried the Behringer first and it sounded really good. Who knew?
  5. Bongocaster
    Bongocaster Friend of Leo's
    From the home of King Records
    Yeah, why not. I've done it with different SS amps over the years. Although I do use magnetic soundhole pickups.
  6. syrynx
    syrynx Tele-Afflicted
    Homesick Texan in Maryland
    I'm very happy with the sounds of my acoustics (including a couple of "little Martins"-- 0-18 and 0-15) through my Peavey Backstage 50. Like Bongocaster, I'm a magnetic sound hole pickup user.
  7. Bongocaster
    It definitely sounds good enough in a band setting. For solo acoustic you might want better.
  8. J. Hayes
    J. Hayes Friend of Leo's
    Virginia Beach, Va.
    Are you sure that amp's not 65 watts?.......JH in Va.
  9. el cheapo
    Southcentral Pa
    Yep.
  10. Greg.Coal
    Greg.Coal Tele-Afflicted
    Colorado
    Some people obsess that an amplified signal should sound "exactly like my guitar!"
    Well, okay, it can sound like whatever you want .... Having just sold a Bandit 65, I won't believe the Bandit sounds exactly like your guitar. But if you like it, that's cool. The Dobro was only ever supposed to sound louder - we love the unique resophonic sound now.
    I always prefer light compression on acoustic and some delay makes it sound bigger. A KB1 is a great tool to have around; I just sold a KB60 - but with an eye towards getting a newer one. They're like powered speakers with an optional pre-amp stage.
    Greg
  11. el cheapo
    Southcentral Pa
    I took a little time tweaking the ADI 21 and the amp, and I have to say it sounds pretty good to me. I'm using the low gain input, and the volume setting has to be right for it to get the string dynamics (especially when strumming chords). That seems to be the acid test.
    A couple of you guys have recommended some light compression and I'll probably give that a try. Should I put the compressor before the ADI 21 or after?
  12. Greg.Coal
    Colorado
    I guess I would do before - but I can imagine good reasons to do after as well. My Baggs DI actually has an effects loop in it - suggesting to me a compressor can go after EQ.
    Greg
  13. el cheapo
    Southcentral Pa
    I put the EQ in front of the compressor and gave it a go. A little compression does indeed sound good with the acoustic! It sure is nice to get advice from all you guys. Thanks!
    I was also able to get a very good sound with my favorite pick. It's a little stiff, and was making kind of a scraping noise when I strummed. I dialed back the attack a little and now it sounds more natural. I'm actually a little surprised by how good this setup sounds. :eek:
  14. DavidM1
    DavidM1 Tele-Holic
    Tasmania
    I thought that was a keyboard amp but now I realise it is a guitar amp so I've just edited out my last comment!
