Whatizitman
Picked up a little Kay 503 (I think) widowmaker on the cheap cuz it’s not powering up. PO said they had a shop add fuse and 3-prong, and that it was working when they picked it up. I tried it on my light bulb limiter and got nothing. Filaments dead. Fuse had heat shrink, so I had to peel it off to see. Looks OK. Well, except for the manner of wiring. But I’ll attend to that later.
The ground side of the main is soldered to the ground tab on the cap can. If the amp ever had an iso transformer it ain’t there no more. I haven’t done any further testing, given the potential angry nature of a widowmaker Kay.
I will more than likely get an iso transformer, change caps, etc… But I want to know all that I have before I buy parts. I get that a 1:1 transformer won’t cost much. But what do I do with the filament series? Ok to keep it direct from mains?
What should I check next, and how to do it safely? My current limiter is a high wattage bulb, so I’m not even sure it would show a short at mains voltage(?).
Any ideas are helpful. Even the inevitable “don’t walk away. Run” responses.
