RickatAscap
That sounds like a very smart idea, thank you for that. All good on the support I get here, wonderful if I may be so boldThere have times when I had to fix something quickly and didn't have time to craft a new nut. I simply popped the old nut out of the slot and cut a shim from a very thin piece of veneer to raise the old nut in the slot. Saves a ton of work and performs just as well as a brand new nut if you do it correctly. You can even use this method as a test to see if this solves your problem. Just don't glue the nut back in if you're replacing the nut altogether.
This approach will give you a chance to practice the repair before committing to it.
Hint: Use a brand new Exacto blade, or razor blade, and heat it, to cut the lacquer/poly that seals the nut ends in the slot. If you don't, you stand a good chance of chipping the finish over a larger area.
