I am gonna build a Tele
Discussion in 'Tele Home Depot' started by bamboofrog, Mar 18, 2009.
  1. bamboofrog
    bamboofrog TDPRI Member
    Bromley, Kent
    Hi all
    This is my first post and my first ever build. I have very limited woodwork skills so progress is likely to be slow.
    Ok the build is going to be pretty traditional. Two piece swamp ash body and maple neck.
    I am going to have a go at building the neck myself, so I have a maple blank and have tried to make things a bit easier by getting a pre-slotted maple fretboard.
    Chrome hardware, possibly a mini humbucker in the bridge but I am still undecided.
    So here goes:
    So I made a bit of progress, the pieces of swamp ash were not quite square for glueing , so I got my plane out and had a bit of go.
    I got a little over enthusiastic and managed to make these even worse.
    But came back it to it the next day with an engineers square to see where things have gone wrong and sorted the problem, amazing what a couple mil does to put things out.
    Got it glued up and put on the sash clamps and left it for 24hrs
    Now the moment of truth, did my first attempt at joining to bits of wood work out?
    Well it seems to have, not perfect but for my first attempt I am pretty pleased. Got a busy couple of days at work ahead now so will probably have to wait for the weekend to get on with anything else.
  2. bamboofrog
    Bromley, Kent
    Postman left me a present. Nearly done now, just need to cut around everything:D
  3. jkingma
    44°55'09.9"N 79°25'39.1"W
    Admin Post
    Thats a gorgeous body blank. Don't f#@* it up... :D
    BTW, welcome to the forum. I'm looking forward to seeing your progress. Looks like you are on the right track so far.
  4. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Albuquerque, USA
    Nothing to it ............. just cut, rout and sand away everthing that doesn't look like a Telecaster.........[​IMG]
  5. Schizotronic
    Schizotronic Tele-Meister
    Brazil
    NICE wood you have in your hands. Good luck. It seems you're on the right way. All the luck at the time of routing the neck pocket. Consider doing it first, so you have more "meat" around it.
  6. bamboofrog
    Bromley, Kent
    Cheers all, I will try my best not to mess things up. My template should arrive for the weekend, then on with the show!
    It is the neck that gives me the most nightmares, but I intend to take things slow and if things go really bad I will grab a ready made one.
  7. jkingma
    Admin Post
    Building a neck isn't really that hard. Its just a bit time consuming to get it right. Do some research here. There are some great neck building threads here. Take your time and feel free to ask lots of questions.
  8. ryguy76
    ryguy76 TDPRI Member
    Campbell River, B.C.
    oooh.... I'm excited for this thread. Similar places you and I are in, except you're starting before me. I'm gonna see what I can learn from you.
    Good Luck!!
    Ryan
  9. Colt W. Knight
    Tucson, AZ
    gotta love that grain. Hope everything turns out great.
  10. Colt W. Knight
    Tucson, AZ
    I concur.
  11. bamboofrog
    Bromley, Kent
    Made a little bit of progress, my templates came on monday and so I got the body roughed out.
    Pretty pleased with how it went with the jigsaw, better than i anticipated.
    Need to have a practice with my router before I let myself loose on the body.
  12. Schizotronic
    Brazil
    Good, man. Now onto the sand, rasp, scraper... Be brave. And go slowly since some of these rough cuts were REALLY close to the line. Good luck.:eek:
  13. bamboofrog
    Bromley, Kent
    Fire up the router
    Stuck down the template, took a deep breath and started up the router.
    I am pretty pleased with the result that tape is bloomin' strong I struggled to get the template off, so on the other side I used a bit less tape and had a bit of an accident, the template slipped a bit leaving a bit of ridge, d'oh. :rolleyes:
    I could do with a drum sander to even it all out, but I haven't got one of those. Any suggestions for cleaning it up?
  14. snosewo
    snosewo TDPRI Member
    Nova Scotia Canada
    That is a nice piece of ash....sorry had to, nobody else has said it yet... :)
    Good luck with the build, can't wait to see how it turns out! What type of finish are you going to use on that bad boy?
  15. tcarp
    tcarp Tele-Holic
    rockaway nj
    sorry...zigged when I shoulda zagged. I posted in the wrong spot.
    Tom
  16. Schizotronic
    Brazil
    Did you use a router bit with a ball-bearing guide? Now I see what you mean by "the (*&#$$# template:twisted: moving away...)
    I would go with the old fashioned scraper blade to finish the side shape. I will tell you MY reasons why:
    - a sharp scraper will remove wood in a controlled manner. I mean, you can get superb control about WHERE and HOW MUCH wood you remove;
    - it will show "hidden" lines of regions that are not square (however your cuts and routing seem perfect to me) as you pass it onto the wood
    - this will give you more confidence to use your hands during the neck shape process
    - and specially, about control yet, the chances to ruin your excellent job so far are very small with a hand tool like this.
  17. bamboofrog
    Bromley, Kent
    Cheers for the encouragment and advice, I was think of using a spoke shave to clean things up. I will have a go this evening and let you know the result.
  18. bamboofrog
    Bromley, Kent
    All cleaned up
    Paid a bit more attention this time and got the body all cleaned up, all grooves and ridges removed :D
    (sorry for the grainy pics, camera phone is all I have to hand at the moment)
  19. bamboofrog
    Bromley, Kent
    Lets make a neck ... or at least have a go
    So on with the neck. Drew out the basic shape from the template, marked off the truss rod and set up the router. Deep breath, and some gentle passes with the router
    http://i399.photobucket.com/albums/pp78/bamboofrog/IMG_0264.jpg
    Took a little fine tuning but it seems to fit well. I presume you install the metal side/plate down?
    Now I need to glue dow the fret board and the cut out the shape, or should I cut out the neck then glue down the fret board?
  20. bamboofrog
    Bromley, Kent
    Installed the truss rod (the right way up), shaped the neck and fret board
    then glued it and clamped it all together.
    Seems to be going ok so far.
