I am about to start my first amp build.
Discussion in 'Shock Brother's DIY Amps' started by Ironwolf, Sep 5, 2020.
  1. Jason McG
    Jason McG TDPRI Member
    Calgary Canada
    hey Ironwolf, I see Stewmac specs out a bipolar 250uF 25V aluminum electrolytic. what do they supply with the kit? mind posting photo of it, with the manufacturer and specs? I am following their build layout, but can't seem to find a bipolar cap. Wonder if it can be substituted with a standard polarized cap? thanks!!
  2. Ironwolf
    Ironwolf Doctor of Teleocity Gold Supporter
    Boise, Idaho
    I have that one installed on the board already. It is marked as a Sprague Atom TVA1208. It is not marked as bipolar so I installed it with the markings oriented as the wiring diagram indicates. Hopefully, it is either bipolar or the orientation will be correct.
  3. _Steve
    _Steve TDPRI Member
    Los Angeles
    Great thread and the build is coming along nicely!
    Would you mind taking a closeup photo of that sticker on top of the output transformer? I too am curious what iron they are supplying with the kit.
  4. Lowerleftcoast
    california
    The sprague datasheet lists the tva1208 as polarized so follow the markings.:)
  5. Ironwolf
    Boise, Idaho
    More info on the Sprague capacitor in question. The wiring illustration shows the turret 52 connection from the cap leading to pin 8 and pin 3 of V1. The circuit diagram indicates that the cap is oriented with the + towards V1 which is how I have it mounted. I am going to call StewMac to verify this.
    Jason McG and 8barlouie like this.
  6. Lowerleftcoast
    california
    I looked at the stewmac instructions. Yes, the positive side of the cap should be towards the V1 (turret 52).
    No worries.:cool:
  7. Ironwolf
    Boise, Idaho
    I received an answer from StewMac support, and they also confirmed the orientation of the capacitor is with the positive terminal towards V1, i.e. attached to turret 52.
    Jason McG and Lowerleftcoast like this.
  8. Mongo Park
    Mongo Park Tele-Afflicted
    Winnipeg
    Since you have not put anything on the tube sockets I would twist up the heater wires a little mor at the sockets. At the sockets is where the twisting has a good effect since other parts And wires will be close bu on the sockets. Can’t hurt if you get him when it is finishes it is hard to get at the heater wires and twist them some more
    Cheers Ron.
  9. Ironwolf
    Boise, Idaho
    Worked on the turret board today.
    Got about half way through and broke for lunch.
    By the end of the day I had everything populated (including the back which isn't shown). However, there was one part missing. a 1/2 watt 15K Ohm resistor which mounts between turrets 26 and 37. I already ordered a small pack which should be here Monday.
    In the picture, some lead trimming remains to be done. It has been.
    I was asked to show the labels of the transformers. Here is the power transformer.
    And the output transformer.
    Tomorrow I'll take a soft tooth brush and my can of flux remover and give the board a good scrubbing.
    Jason McG likes this.
  10. Ironwolf
    Boise, Idaho
    Cleaned up the board and installed it.
    The testing did not go well. The initial voltage tests were spot on, but as I started testing the gain stages and tone stack circuitry, readings were all over the place.
    I began by retesting all the connections. The solder joints and grounds all tested good. Continuity from the board connections to the filter caps, pots, and tube mounts all tested good. I then started re-checking individual components.
    I discovered a couple of resistors that were not passing current. I replaced them and retested from the beginning. Everything checked out. I adjusted the power tube bias and plugged into a 2x12 cab and tried a guitar. It sounded great.
    Here is the chassis after the trouble shooting and rework.
    I mounted the chassis in the cabinet and closed up the back.
    This is how it looks assembled.
    This has been a very educational and fun project. I will be casting about for similar projects in the future. If I can get my recording gear setup and working, I will try to add some sound clips in the future. In the mean time, this has replaced the Origin 50 in my wet/dry rig.
    Gleesonjf, LiteAsh, SacDAve and 9 others like this.
  11. Blue Bill
    Wow, Wolf, that is awesome. Nice job.
  12. awasson
    awasson Poster Extraordinaire Silver Supporter
    Vancouver
    That’s a really nice looking amplifier. Nice job.
  13. Kevin Wolfe
    Kevin Wolfe Tele-Holic
    Lakeland FL
    Nice looking work.
  14. Ironwolf
    Boise, Idaho
    The final step. Added my own name plate.
  15. Ironwolf
    Boise, Idaho
    I just wanted to do a fast follow up on this amplifier's performance after 4 months of daily use.
    As it has been "broken in", it has become mellower in tone and with the correct settings has proven to be very usable and pleasant sounding with everything from an LP Standard 50s and a higher end 335 to a Squier CV Jaguar. Single coils, humbuckers, filtertrons and P90s all sound fantastic with EQ tweaks for their distinctive sounds. For me the optimum blend setting for my style of playing is setting the Normal volume to 3 and the High Treble volume to 6. This maintains the amps clean head room with the ability to go into a pleasent crunch with the application of a slight boost or a drive pedal with the gain set quite low.
    This kit is one I would highly recommend for producing a quality end product.
    awasson, 8barlouie and MrCoolGuy like this.
