RedPillBlues
So in an effort to start working on my own instruments I’ve slowly started taking on things. Did a couple of fret levels and crowing with little issue except for scraping up my finger board even though it was taped. I’ve learned to live with the scratches and have sanded and micromeshed them mostly out.
Started soldering which I’ve found Fairly straight forward. Made the decision to switch gauges to 11’s and got a new nut. Long story short I worked the nut seating slot a little too much when I should have stopped and as a result I’m here now. Did most of the damage with a nut seating file and exacto life trying to scape out old glue.
That’s a tusq pre slotted flat bottom with about 5 layers of apple accessory box exacto cut and superglued to it. That made the guitar playable…. I set it up. Intonated with my strobe tuner and it plays surprisingly well with only a few intonation issues here and there. I have these Spanish cedar veneers and a board of roasted maple which is the same material as the neck.
So I’m looking at a kinda v shaped slope with a nut that rocks to either side (without my cardboard shim) although my straight edge is fine in the slot. Radius of the board is supposed to be 13.7”
Any advice? Square off the sides and bottom and then shim the sides and bottom of the slot using the wood and super glue them? Maybe it’s just a case of making a custom nut for this guitar? I know your supposed to work the nut and not the slot but you live and learn I guess.
