Hummmmm
Discussion in 'The Stomp Box' started by schmee, Jul 23, 2019.
  1. schmee
    schmee Poster Extraordinaire
    So I have a small pedalboard with multi effect, OD and two Ditto loopers for Duo gigs. I noticed in the garage today that things were humming. I also noticed if I turn the OD ON, it's dead silent. Humbucker guitar. Go figure.
    Any thoughts on why it hums with the OD OFF?
    I would expect the opposite.
    Another weird thing I didnt realize until today. If I have a loop playing back, turning the guitar up (playing over the loop) makes the loop louder. Whaaa?
    Guitar>Looper> Amp. Not logical either.
  2. lefty73
    lefty73 Tele-Afflicted
    Are the pedals connected in series? That is:
    Guitar>multi-effect>OD>Ditto 1>Ditto 2>amp
    • Has this hum happened before, or is it a recent occurrence?
    • What type of power source(s) are you using for these pedals?
    • How new or old are the patch cables between them?
    • How new or old is the cable from your guitar to the multi-effect (or whatever the first effect is)?
    • How new or old is the cable from second Ditto to your amp?
  3. schmee
    I notice it now and then and frankly not sure if it's always there. I dont remember it at gigs so far.
    But what has me weirded out is having the hum with the OD off. You'd think it would be with it on.
    Just a wall wart.
    Old mostly
    New, other cable is the same.
    New
    I need to do some more diagnosis obviously. I just thought of it and made this comment. I'll put another OD in there and see if the same reaction occurs.
    My other comment really surprised me, and I have noticed at gigs sometimes that the looper track seems too loud. Probably due to turning up a bit to solo over the loop. Yesterday I noticed that the looper volume is driven by the guitar volume EVEN WHEN THE LOOP IS ALREADY RECORDED AND NO LONGER RECORDING. That seems totally weird to me and I can't really logic how it even works that way. I guess it's a Ditto thing. You'd think it would be just like a recording set at the recorded volume.
  4. ecoast
    ecoast Tele-Holic
    NWNJ
    You need an isolated power supply.
    certain pedals, when used with other certain pedals, create all kinds of issues if they are on a daisy chain...
  5. Obsessed
    Montana
    My initial reaction is that dual loopers could cause some havoc. I think you would have to manage their use with a lot of thought before hand.
  6. schmee
    It takes some thought for sure. But I just use them separately and have dedicated kill switches so as not to get problematic when singing and looping etc! Immediate kill without a double tap etc.
    With two I can do an instrumental "intro" backing track and solo intro over it, then off and do the song body for a real solo later if I want. It works well.
    Obsessed likes this.
  7. schmee
    I've not had that issue on my big board, but maybe I'll try with a battery on the OD and see what happens.
  8. Obsessed
    Montana
    Got it. I use two loopers in series once in awhile, that made me think about what could happen, but I see that you fully understand the method. Nice.
  9. schmee
    I dont know, I think it's my garage. I tried cords, power supplies, different amps today no change. I even tried a Variac on the amp to isolate the power. No change.
  10. Lies&Distortion
    Lies&Distortion Tele-Holic
    SE Michigan
    Try it someplace else? You didn't notice at gigs, so garage seems likely.
