Humdinger physical location
Discussion in 'Shock Brother's DIY Amps' started by Tom Kamphuys, Oct 15, 2018.
  1. Tom Kamphuys
    Tom Kamphuys Tele-Holic
    The Netherlands
  2. clintj
    clintj Friend of Leo's
    Idaho
    How about the gap between the PT and main board? You should be able to detour the heater wiring enough to reach the pot lugs easily, looking at the stock chassis arrangement.
  3. robrob
    United States
    You can tie it into any place along the heater chain so put it wherever you want. Twist the wires running to the pot.
  4. Tom Kamphuys
    The Netherlands
    And how would you mount it? Panel (Chassis) mount (pot), terminal strip, ground lug terminal,...
    Or does 'tie' imply dangling from the heater wires?
  5. clintj
    Idaho
    If it was a full size standard pot, I might stick it to the chassis with a little RTV on the back. I've done that with mini sized trimpots in bias circuits.
    Attached to a dedicated tag strip with the center lug grounded would be pretty solid, which is a good trait in mobile equipment like guitar amps.
    Third idea is the standard Fender chassis mounted like their bias pots, but you shouldn't need to access it after it's dialed in.
  6. Tom Kamphuys
    The Netherlands
    robrob and Wally like this.
