Humbucker pickup slide-switch wiring
Discussion in 'Just Pickups' started by Holyman556, Feb 27, 2021.
  1. Holyman556
    Holyman556 TDPRI Member
    Missouri
    So I just acquired a squire mustang with Seymour Duncan 4 wire humbucker pickups in it. It's has unusual wiring in it for a mustang. 2 typical dt3t but one is wired as a 3 way switch and the other as a rhythm circuit for the neck pickup only. I want to change the rhythm circuit to be a north/south coil split. What I would to know is if I can wire it so it will split both pickups with one slide switch at the same time.
    In the image above can you add the other pickup to the right side and it will split both pickups simultaneously? If so will there be any phasing or any other issues I should be aware of?
    Thank you for everyones time.
    itsmedant likes this.
  2. itsmedant
    itsmedant Tele-Meister
    Virginia
    When you say “split the pickups” are you asking if both pickups can be selected independently or run together when in the middle? Or are you wanting to “split” each pickup like with coil tapping?
  3. Holyman556
    Missouri
    Coil tapping. Like for example if I selected the north coil on the dp3t it would be for both pickups regardless of what position the selector switch is in.
