whoanelly15
I’ve got one for you, fine folks of this TDPRI. Recently switched out the bridge humbucker on a guitar for another, lower output one. Everything else was left alone. The guitar is an HSS configuration, 5-way switch. Quickly realized that the humbucker was out of phase with the middle pickup, which appears to be RW/RP relative to the neck pickup, as position 4 is hum-cancelling. So, I switched the hot/ground leads of the bridge pickup to reverse phase. Everything sounds great now!
Except… the humbucker has what sounds like a 60-cycle hum. I’ve read up on some similar issues people have experienced, but without anything that makes a ton of sense in this setup.
Thoughts? Thanks in advance.
