basso
5F2A build, hums at zero but as soon as you inch the volume knob up it goes dead quiet and the amp works perfectly. Voltages look good, measuring the 2nd half of V1 (pin 6 or 8) eliminates the hum completely with the DMM on the pin, measuring all B+ voltages quiets the hum and gets quieter the farther down the line you go. Touching the shielded cable from the volume knob quiets it some which leads me to grounding but it goes away when you move the volume knob so that doesn't make sense.
So far I've replaced the 12AX7, volume knob, disconnected the tone control, replaced the shielded cable from pin2 on the volume to pin 7 on V1, of course I've made sure the grounds are good, hoping someone has an idea
