HT Bleeder Idea
Discussion in 'Shock Brother's DIY Amps' started by andrewRneumann, Jun 10, 2021 at 11:36 PM.
  1. andrewRneumann
    andrewRneumann Tele-Holic
    Cincinnati, OH, USA
    Has anyone ever contemplated incorporating an HT bleeder like this (with a fuse of course)? Pros / cons? BLEEDER (2).png
  2. Lynxtrap
    Lynxtrap Tele-Holic
    EU
    Not sure what that is supposed to accomplish...?
    IMO no wiring should be based on the assumption that neutral will be neutral at all times.
    In many countries it is totally out of the question.
    Lowerleftcoast likes this.
  3. NTC
    NTC Tele-Holic
    Maybe if you connected the bleeder to the ground lug, but there are still no guarantees it is ground. And again, why? Unless you plan to open and work on the amp every time after it is turned on, you really don't need to drain the caps at power down.
    andrewRneumann likes this.
  4. 2L man
    2L man Tele-Meister
    Finland
    Both a bleed and a filament lift can be done using the same circuit which contain two resistor voltage divider and one electrolyt over bottom resistor.
    Between power transformer primary and secondary there shouldn't be ANY CONNECTION because it is electric risk!
    NTC likes this.
  5. andrewRneumann
    Cincinnati, OH, USA
    Exactly. I am contemplating this for a test rig. I spend so much time with alligator clips and multimeter bleeding down the HT, wanted to find a quick but SAFE way to do it repetitively.
  6. andrewRneumann
    Cincinnati, OH, USA
    That’s a good point and an easy one to forget.
  7. Tom Kamphuys
    Tom Kamphuys Tele-Holic
    The Netherlands
    Look at the bottom of this page (http://www.valvewizard.co.uk/OtherStuff.html) for some ideas with LEDs. Idea 4 might be a method to easily see the caps drain.
    (Theoretically?) You could use a switch that switches hot & neutral _and_ the bleeder to ground. Or use a separate switch for the bleeder.
    Btw, we've got the same wall outlets as Lynxtrap showed here in The Netherlands.
  8. Nickfl
    Nickfl Friend of Leo's
    Is there a reason you don't want to use a normal bleeder resistor across the filter cap?
  9. wallybob
    wallybob TDPRI Member
    Iowa
    I think that the main electrical flaw in this circuit is that in order to discharge the filter caps, a bleeder circuit would have to involve the neg side of the filter caps. Your switch is connected to the line neutral. Neutral is not connected to cap neg ground in any of the amps I've ever built. Of course, this point is secondary to the fact that there are much more convenient ways of achieving your requirements.
  10. andrewRneumann
    Cincinnati, OH, USA
    I'm a sucker for some cool LEDs! They make you look like a genius to the common folk. Of course, VW is a genius... so he's allowed to have LEDs.
    The goal of this is bleed fast and bleed often. So would like to use a low resistance and not have a separate switch. Your idea of a 3 pole switch is genius. Something like this maybe?
    CORRECTION: It would be a 3PDT switch, not a 3P3T.
  11. andrewRneumann
    Cincinnati, OH, USA
    For speed. I just want to have it drain super fast when I throw the switch, double check it with the meter, and get to noodling around in there. Again, this is for testing/modification. The final amp would have the normal bleeder everyone is familiar with.
  12. andrewRneumann
    Cincinnati, OH, USA
    After looking at it some more and reading the group's input, I think the main safety flaw is that if you unplug the amp while it is running and then turn off the switch, HT is then present on the neutral blade of the plug. Revised drawing above should solve that problem.
    Lynxtrap likes this.
  13. Mexitele Blues
    Mexitele Blues Tele-Afflicted
    Westminster, CO
    I used a 220k to ground directly after the rectifier. By the time I could grab my multimeter and check the caps, they were down to single digits, and the act of checking drained the remainder. I don't think there's much time to be saved.
  14. Tom Kamphuys
    The Netherlands
    That is probably with (hot) tubes. They conduct way more than the resistor.
    For a (total) capacitance of 50uF, a 220k resistor drains the caps to ~60% (of the charge and thus voltage) in 11 seconds. And a further 11s to get to 60% of that (so 36% of the original voltage).
