HSS wiring diagram help
Discussion in 'Tele-Technical' started by maktoasty, Aug 11, 2016.
  1. maktoasty
    maktoasty TDPRI Member
    Hello, I am working on a wiring project for an HSS tele with a volume and 2 tone controls. I am using an S1 switch and a 5-way super switch
    I have worked out a wiring diagram that can accomplish the pickup selections below, But I am having trouble working in the tone controls
    here is the hopeful end-result, all combinations are in parallel unless otherwise noted. Bridge HB splits to screw coil
    Pos. 1 (S1 up) Bridge HB Pos. 1 (S1 down) Bridge HB and Middle (in series)
    Pos. 2 (S1 up) Bridge split and middle Pos. 2 (S1 down) Bridge split
    Pos. 3 (S1 up) Middle Pos. 3 (S1 down) Bridge split and Neck
    Pos. 4 (S1 up) Middle and Neck Pos. 4 (S1 down) Bridge split, Middle, and Neck
    Pos. 5 (S1 up) Neck Pos. 5 (S1 down) Neck and Middle (in series)
    The problem I am having is with the tone controls. there are two options for the tone controls that would be acceptable
    tone 1 for the bridge pickup, tone 2 for neck and middle pickups
    -OR-
    tone 1 for pos. 1 and 2, tone 2 for pos 3, 4 and 5 (this would be preferred)
    I am curious what the best way to get the tone controls connected would be, and if anyone has an idea of the most efficient way to wire the pickups as well?
    As I mentioned before, I was able to get a diagram together for the pickup combinations, but it only allows room for tone 1 on positions 1 and 2
    I can get tone 2 on positions 3 and 5 but anything on 4 would just be grounded out or create unwanted pickup combinations.
    any help would be greatly appreciated.
  2. maktoasty
    I am reposting the pickup selections to make them easier to read:
    Pos. 5 (S1 up) Neck
  3. AAT65
    AAT65 Poster Extraordinaire
    West Lothian, Scotland
    I'll give my usual suggestion - give up on Leo's 2 tone controls idea and wire it up with Leo's newer Passive Treble and Bass (PTB).
