How Would You Improve Telecaster Design?
Discussion in 'Telecaster Discussion Forum' started by black_doug, Feb 12, 2020.
  1. LightningPhil
    LightningPhil Tele-Meister
    Nottingham, UK
    Hollow out the back. Install the guts of a dirt pedal, a class D amp and some batteries. Then it could be observed directly into a cabinet without an obvious amp. It would be a magic ampless tele with extra high output.
    Or, more sensibly, boat loads more shielding, noise cancelling pickups and a zero output impedance active buffer for the ultimate low noise experience.
    mooncaine and black_doug like this.
  2. guitartwonk
    guitartwonk Tele-Meister
    People's Republic of Blighty
    That there is what we call "agricultural".
  3. BeatTellender
    BeatTellender TDPRI Member
    United States
    Definitely agreed! This video here proves how a stratty neck pickup can make much of difference in clarity and tone! The rhythm guitarist is using a telecaster with a telecaster neck pickup that is exposed but it has black plastic cover similar to a strat cover pickup. I don't know if it sounds stratty but you can hear glassy, chimey, bell-like tones. Also note the amp he's using isn't known for giving a clean tone like this!
    Sent from my SM-A102U using Tapatalk
  4. anthrotony
    anthrotony Tele-Meister
    France
    Thanks so much for all of this. That guitar looks quite amazing and I'm sure it sounds equally as good. I had no idea that Jorgensen played a tele with a JM configuration. I'll have to look up some of the YT videos to see if I can find an example. I'd read that he played a Strat with some sort of JM pickup in the bridge position which sort of makes more sense (well, to me at least), and if I'm not mistaken, I remember seeing a Tele with parallel adjacent bridge pickups although I have no idea what the purpose was. Cool though. So many different ideas out there!
    Cheers!
    telemnemonics likes this.
  5. FelixV
    FelixV TDPRI Member
    Cardiff, UK
    I wouldn't change a thing but if i had to, I'd recommend
    Body and forearm contours.
    6 way switch.
    1 stacked concentric knob that is tone and volume.
    The output jack moved to the control plate.
    Brighter neck pickup.
    black_doug likes this.
  6. AngelStrummer
    AngelStrummer Friend of Leo's
    London
    Compared to the original 50s design only the following few:
    - Modern wiring
    - 9.5" fretboard radius
    - Medium jumbo frets
    All the rest is perfect to me.
    Greggorios and black_doug like this.
  7. Dirty Dave
    Dirty Dave TDPRI Member
    Bucks, UK
    This.
    - and possibly smooth off the fret ends just a little bit on the lead side of the neck.
  8. Speedfish
    Speedfish Tele-Meister
    Southern United States
    I like what Jeff Beck did with his Telecaster.
  9. guitartwonk
    I'm curious...
    Contours: if you want these, why not go for a Strat?
    Have you ever tried to operate stacked knobs mid-song? I have. Immediately resolved never to install stacked knobs ever again.
    6-way? Why would you want 6 options on a two pickup guitar? I have a Tele with 5 so I can barely talk, but I'm really curious what switching options you'd want.
    Brighter neck pickup: again, a Strat may be more suitable....?
    Pure opinion here, of course.
  10. funkysoul
    funkysoul Tele-Meister
    greece
    if 6 saddle for better intonation added then nothing at all
    black_doug and guitartwonk like this.
  11. Twang Deluxe
    Twang Deluxe Tele-Meister
    Kehl
    Not much. Just to file a bit the sharp edges of the vintage style bridge and wire the middle position from parallel to series.
  12. FelixV
    FelixV TDPRI Member
    Cardiff, UK
    The simplicity of the telecaster is what makes it cool but if you’re gonna mod it you might as well give it the works!
    Having the single dual knob means you can have the output jack on the front, which allows you to play sitting on the floor and also be able to put it on a stand plugged in.
    The pickup combinations would be,
    N
    N+B parallel
    N+B series
    N+B out of phase
    B
    Either “jazz/bass’ neck or bridge direct out (tone bypass)
  13. chiefline
    chiefline Tele-Holic
    new jersey
    make her look like Charlize Theron. Just my opinion...
    Fiesta Red likes this.
  14. chiefline
    new jersey
    Definitely put a condom holder in the back of the body . Need it for all the women who throw themselves at Tele players
  15. gobi_grey
    gobi_grey Tele-Afflicted
    clinton, ia
    I'd like to hear what a tele sounds like with the bridge pickup moved about a half inch away from the bridge. Maybe even just a quarter inch.
  16. gobi_grey
    clinton, ia
    Ooo, pickups in series and bypass the tone pot in that position to add a little more clarity.
  17. stratoman1
    stratoman1 Friend of Leo's
    Virginia Beach, Va
    I like mine how it is. Belly cut and six saddles.
  18. black_doug
    black_doug Friend of Leo's
    Toronto, Ontario, Canada
    That's one thing I would prefer not changed. I like my Tele without a belly cut.
  19. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    There is so many overlapping feature requests between Tele and Strat ... maybe the solution is what features should be on a hybrid Tele-Strat?
    There were a couple of Parallel Universe models that were sort of like this.
    Strat Neck pickup
    Tele Bridge pickup
    Single cut Strat body?
    Tele Controls (so the Strat volume knob is at the first tone knob position) for more playability back by the bridge.
    Strat angled top mounted jack.
    Strat headstock?
    Jaguar middle pickup (to go a little off the hook)
    Seven-Tone Strat wiring for Tele neck and bridge parallel option?
  20. stratoman1
    Virginia Beach, Va
    My first guitar was a 74 Tele, so yeah, big and slabby. I got used to my Strat though. The Tele doesn't have the arm contour so it's still a little beefy. If I want to go full on heavy slab I have a couple of Les Pauls to scratch that itch
