How would you approach this color?
Discussion in 'Finely Finished' started by chillman, Mar 1, 2020.
  1. chillman
    chillman Tele-Afflicted
    I'm starting another tele build after being tele-less for years. I have a specific vision in mind, and it includes getting as close to this color as I can:
    It's a Lexus color called Fire Agate Pearl, and it really wowed me when I saw one in the grocery store parking lot. It's a sort of chocolate metalflake with an iridescent spectrum from taupe to oxblood.
    I'm looking for advice on the application, or feedback on my current plan, which is:
    • Black base coat
    • Root beer metalflake coat
    • Red or gold pearl clear coat?
    My main question is in the pearl. I've never used pearl before, and I'm tempted to skip it. A tele is flat, and pearl is most noticeable in contours.
    I would be using basic SW Lo-VOC lacquer, not automotive urethanes.
    Any advice?
  2. old wrench
    old wrench Tele-Afflicted
    corner of walk and don't walk
    It sounds like you've got your own spray rig, since you're using LoVoc.
    My suggestion is to use real Fire Agate Pearl; if it's only available in urethane, so be it.
    I think that's the only realistic way of getting that same color with the pearl effect.
    I've found that pearls will make any flaws in a painters technique (like, my own;)) show up pretty quickly :).
    eallen likes this.
  3. Buckocaster51
    Iowa USA
    Admin Post
    You could go to an automotive paint supplier and get a pint of base coat... that is why they open their doors in the morning
  4. Silverface
    Lawndale CA
    Pearls aren't hard to spray - with practice. Like any unfamiliar coating you should apply the ENTIRE system on scrap several times to refine your technique and learn how products interact. A single product in a 4 or 5 product system can change the way another product not even in direct contact with it will affect the overall look.
    One tip - I never use pearlescent additive in the clear coats. I use them in toners orr in the initial clear coat, with several straight clears over it. Buffing can really foul the look of a pearl if the pigment is in the final coat; and because lacquers melt into each other it's best to do the best job possible and do NO wet sanding - just buffing.
    Any pearl pulled into the final clear coats can really be screwed up by wet sanding, which is actually a repair process except with certain systems. Most lacquers finishes should not be wet sanded unless mistakes were made in application. No professional finishers I know wet sand (except when doing certain vintage type Gibson finishes, which take years of experience). I even use aerosol's for small jobs or when I'm lazy and don;'t want to pull out one of the HVLP's, and I haven't wet sanded in years.
    dan40 likes this.
  5. DrASATele
    North of Boston
    100% right on, it often takes someone unfamiliar with finishing products more than a few attempts to get to this way of thinking and ability (it did for me). I use to swear getting the perfect coat without wet sanding was like seeing a Unicorn, now not so much. Prep as always is key to a great finish.
