How Tough Is It To Bend a Tremolo Arm?
Discussion in 'Bad Dog Cafe' started by Southpaw Tele, Jul 18, 2014.
  1. Southpaw Tele
    Southpaw Tele Friend of Leo's
    The Golden State
    Meaning, if I buy a right handed Mustang trem arm, could I bend and shape it to be close to what a lefty trem arm would look? Lefty Mustang parts are few and far between.
  2. lendryesky
    lendryesky Tele-Afflicted
    Michigan
    My guitar tech bent a mustang arm for me back 12 years ago. It was right handed but needed to be at a more acute angle so it didn't pop out from the body too much. I'm not sure what he used to do it, but it can be done.
  3. Southpaw Tele
    The Golden State
    Awesome! I was thinking of vice, vice grip pliers and heating it up. They're cheap enough that I can afford to muff it up. Thanks for the help!
  4. ASC67
    ASC67 Friend of Leo's
    Minneapolis, MN.
    I don't think that it would be too difficult to bend. Some clamps and or a vise would be all you would need.
  5. Telesavalis
    Telesavalis Friend of Leo's
    Deep in the Heart O Texas
    the vice>propane torch>heat>bend idea will certainly work,
    might melt the plastic tip though.
  6. Blue Bill
    Blue Bill Poster Extraordinaire
    It's easy. Remove it from the guitar and clamp it in a bench vise. Use a piece of soft wood on either face of the clamp jaws to protect the arm from scratches. Bend away. It will tend to bend just above where it is clamped, so you may need to re-position and re-clamp it several times. If you are trying to adjust the right angle bend near the threaded end, clamp the long part in the vise, and use a small metal tube to bend the short part. Again, use plenty of tape on the arm to protect from scratches. A 4-way screwdriver, with the bit removed, will work fine. Good luck!
    (edit): I would avoid the torch. It will certainly ruin any plating, and it isn't necessary.
  7. Justinvs
    Justinvs Poster Extraordinaire
    Wise River, Montana
    +1
    I bent the trem arm on my Ibanez RS this way so I could tap individual strings with it. Just take your time and keep checking it. Easy to go overboard.
  8. studio
    studio Poster Extraordinaire
    California
    I bent an arm by drilling a hole in
    a piece of 2x4 and sticking the arm
    threaded part in there. I then
    proceeded to bend it to my liking.
    Worked great for me and no scratches
    to the "chrome" finish.
  9. jmiles
    jmiles Friend of Leo's
    ohio
    Or make one from scratch?
  10. TheGoodTexan
    TheGoodTexan Super Moderator Staff Member Ad Free Member
    Nashville, TN
    Admin Post
    Wear thick gloves.
    Those things can snap... and leave a bad jagged edge... which can slice through skin like... a sharp piece of hot metal through churned milk product.
  11. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Fort Worth,Tx.
    I bent the trem arm that came with my AV57ri and the "chrome" flaked off around where it was bent.
  12. metalicaster
    metalicaster Tele-Afflicted
    I'm a wanderer...
    I've had success just putting it in a vice and pulling on it by hand slowly.
    back and forth a little more each time
    Disclaimer - if the arm breaks from metal fatigue or something you didn't hear it from me.
  13. Octave Doctor
    Octave Doctor Tele-Afflicted
    Morgantown, WV.
    Using a LARGE bench vise makes it much easier.
  14. Westerly Sunn
    Westerly Sunn Poster Extraordinaire
    S.E. North Carolina
    That is what I was thinking would happen...
  15. Southpaw Tele
    The Golden State
    Okay, thanks again for all the replies. The $9 trem arm showed up yesterday. Should I make the bend attempt at position #1 or position #2?
  16. bloomz
    bloomz Tele-Holic
    Somebody's Mom's house
    position 2 imnsho
    straight(er) trems look great
  17. Brett Fuzz
    Brett Fuzz Tele-Holic
    Melbourne, Australia
    There is a guy over on the Strat forum calls himself Celt Rocka.
    He custom makes blocks & steel trem arms.
    Highly recommeded!
  18. J-man
    J-man Doctor of Teleocity Ad Free Member
    North Wales
    Admin Post
    Position 2. Less of an angle difference between current and wanted angle, so less work and less chance of it snapping. (In theory)
