How to wire a Baja neck pickup to a 3 way switch of a blend circuit
Discussion in 'Tele-Technical' started by ciccios, Jun 11, 2021 at 9:46 AM.
  1. ciccios
    ciccios TDPRI Member
    Rimini (italy)
    Hi everybody, looking for a little help how to wire a Baja neck pickup BWG wires to a 3 way switch of a Broadcaster/Telecaster tone blend circuit.
    From what I can understand Green and Black are grounds and Yellow is the HOT....
    Here are you both circuit pics:
    Fendereedo and TheOtherNeill like this.
  2. Fendereedo
    Fendereedo Poster Extraordinaire
    England
    Black to me is always ground. The green on the top schematic looks to be ground as well.
  3. Tuxedo Poly
    Tuxedo Poly Friend of Leo's
    Merseyside UK
    Yes, the green is the separate neck pickup cover ground.
    Fendereedo likes this.
  4. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    Yes, yellow would be the COIL positive, black COIL negative, green, cover (shield) grounding.
