How to widen metric sized knobs?
Discussion in 'Tele-Technical' started by hydra19, May 19, 2020.
  1. hydra19
    hydra19 TDPRI Member
    London, UK
    I got a MIJ Tele with some real nice relic knobs, I really like them but could not find a similar replacement to fit 6.35mm (imperial) solid shafts. I prefer these to some that are going for $50 on ebay so surely there must be a DIY way?
    I managed to enlarge the control plate with just a metal round file but the knobs are proving much trickier. I used the file and even resorted to a hand drill, holding knob with a capo but it doesn't seem to be getting much larger. I can see bits of brass coming off from the inside but it still doesn't fit the shaft.
    Should I use a drill but that fits in the hole and use that to widen the sides of the hole or should I go for a bigger drill bit and try to drill that in to fit? Any other tips?
  2. SPUDCASTER
    Grangeville, Idaho
    Machine shop close? Take the guitar with you so they could measure the pot shaft.
    I'm sure they will have a drill press. Couldn't be very expensive.
    Sorry, forgot you're possibly quarantined. It's business as usual here.
    Do you have the right size drill bit? A vise or a pair of vise grips?
    The capo seems pretty unstable.
    I guess just take it slow and be careful.
    Ricky D. likes this.
  3. Matthias
    Matthias Friend of Leo's Gold Supporter
    Have you got a pic of the knobs? It could be easier to get a new set and relic to your own to taste.
    Otherwise, what size drill bit are you using?
  4. Ricky D.
    Ricky D. Doctor of Teleocity
    Raleigh, North Carolina
    You should use a drill that s the size you want the hole to be, slightly larger than the shaft.
    Do not try to hold the knob in your hands. Dangerous. Use a vise.
  5. alnico357
    alnico357 Tele-Afflicted
    Arkansas
    I have done this with a drill bit. It worked fine. 8mm vs 3/8" is not very much.
    BBQedIguana likes this.
  6. hydra19
    London, UK
    should I use a 8mm drill bit, even a 7mm doesn't fit and seems tough. Probably because I don't have a vice so can't give it a lot of pressure or force, I'm just letting it do its own work, but not making much progress
  7. LutherBurger
    LutherBurger Friend of Leo's
    NYC
    He's talking about the knobs, not the control plate.
    6mm vs 1/4"
    Which isn't much, either, but without the proper tools, skill, and safety precautions this could turn out less than well.
    Frodebro likes this.
  8. hydra19
    London, UK
    6.5mm bit just goes in and doesn't seem to be doing much, while the 7mm bit can't go in and is actually widening the top of the hole. I got proper tools, some skill and a little safety precautions but it might be more trouble than it's worth. Thank you for the advice
    LutherBurger likes this.
  9. alnico357
    Arkansas
    I have reamed out brass knobs with a drill bit to fit larger diameter shafts. I clamped the knob in a vise and drilled out the very little material needed. It worked like a charm.
  10. LutherBurger
    NYC
    6.5mm should be wide enough to fit on a 6.35mm shaft, right?
    I'm not a machinist and I can't argue with success, but I don't consider a hand drill and a capo to be proper tools for the job.
    Biffasmum and Jlwctn like this.
  11. Gardo
    Gardo Tele-Holic
    Lancaster Pa
    I've done this same thing ,but then I have a drill press and a vise.
    Frodebro, Jlwctn and dougstrum like this.
  12. moosie
    Western Connecticut
    :lol::lol::lol:
    Me neither...
  13. Frodebro
    Seattle
    Should probably have the first aid kit nearby and ready to go, because the hand drill & capo method tends to cause tissue damage and mild to excessive bleeding.
    tubegeek likes this.
  14. moosie
    Western Connecticut
    Works best on a red guitar.
    Skub and tubegeek like this.
  15. hydra19
    London, UK
    Thanks for the mature comments, keep the jokes comin', they are really helpful in this case
  16. Frodebro
    Seattle
    It was posted humorously, but trying to use a capo for a clamp to enlarge a hole in a hunk of metal with a hand drill is asking for injury.
  17. Si G X
    Si G X Tele-Afflicted
    England
    wouldn't it be easier to change the pots?
  18. hydra19
    London, UK
    Sorry guys, of course I would not risk injuring my playing hand over a couple of knobs. I have given it up for now as I don't have the tools to do it safely. I take my comment back, I do enjoy the humour on here, just wish there was a way for me to do it, I came here for advice, I got it and won't go to those lengths.
    I had injured my hand twice trying to tighten Mosrite bridge nuts, and learned my lesson right there. Thanks for warning me of the danger, I mean that
    LutherBurger and Frodebro like this.
  19. hydra19
    London, UK
    I did get new pots, with a prewired harness so want to make use of that. Knobs are £10 and the least important in terms of looks, since they're all chrome and pretty similar
  20. Telecentric
    Telecentric Tele-Holic
    Boulder Creek, Ca
    * removes capo from 'pliers, clamps and cutters' tool box drawer, and slowly backs out of thread *
