How to test humbucker: series vs parallel?
Discussion in 'Just Pickups' started by Turbogoon, Sep 2, 2014.
  1. Turbogoon
    Turbogoon Tele-Meister
    Hi all,
    I have a Music Man bass hum buckerpickup. How do I know if it is wired in series or parallel?
    cheers
  2. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    Howdy Turbogoon
    I assume it has four wires.
    Do you know what model it is ??
    If you check out these dc resistance readings, and get quite a bit less when you test, then it is wired parallel.
    http://www.seymourduncan.com/comparetones
    For instance the Vintage for P Bass hb would be 11.6 KΩ or about 2.9 KΩ parallel.
  3. waparker4
    Philadelphia, PA
    Take a look at the wiring.
  4. Turbogoon
    Thanks sjtalon. This is really helpful. Basically, the MM Sub (USA version) apparently came out the factory with some models in series, some in parallel (this is unverified BTW!)
    So if there are four cables coming out to the wiring then I can be sure it is series - that is what i'm assuming from your post...
  5. Telenator
    Vermont
    It is most likely wired in series.
    Series is louder and fuller sounding.
  6. KenH
    KenH Tele-Holic
    Pennsylvania
    For series, two of the 4 wires will be joined together and taped off. Only single conductors will be connected to your controls.
  7. sjtalon
    Right, can you look how it is wired. From the pickup to the switch. If they did parallel, it would most likely be a 4 wire pickup to accomplish that.
    So here are some diagrams that shows how it's done with the coil leads. Some (as you most likely know) will wire a humbucker to a switch so they can have the selectable option to have it either way.
    http://www.jacksinstrumentservices....tronics/Humbuckers-in-parallel-and-series.jpg
    coil splitting:
    http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=coil_splitting
