How To Spot Refretted Vintage Telecasters
Discussion in 'Vintage Tele Discussion Forum (pre-1974)' started by Lotion12, Oct 7, 2019.
  1. Lotion12
    Lotion12 TDPRI Member
    Ankara
    These photos are from 2 different Telecasters, 1967 Fender Telecaster Bigsby, 1972 Telecaster deluxe.
    Both are original and both of old owners said that these guitars are all original . If yes I will wait for refretting, but if not, I definitely will go to refret.
    Thanks in advance.
    Love you guys.
    6AA35E3B-8813-415D-A44C-120FCAFB785A.jpeg A95F2CCE-4E09-446F-B0BB-A9EC4BA2C1E0.jpeg
  2. unixfish
    unixfish Doctor of Teleocity Silver Supporter
    Northeast Ohio, USA
    "All Original" is a bit of a misnomer to me. If I were to buy a 1969 Camaro, I would not expect the brake pads to be original, even if it were listed as "all original".
    Are frets from a vintage Tele the same? Unless it was not played much, I'd almost expect them to have been replaced (?).
    If they are not grooved, play it. If they are, replace them.
    I'm not sure if that is what you are asking.
  3. Antoon
    Antoon Tele-Holic
    Low Lands
    Yes, (apart for the obvious incorrect fretwire) you have to inspect the other side of the neck. The slots on the treble side are usually almost 'closed'. The old frets have not been pushed through yet. A slot that seems deeper than the fret is also a giveaway. A refinished or planed fretboard as well. The first neck in the pics seems refretted to me. Not sure abou the second one.
    cjp60 and telemnemonics like this.
  4. telemnemonics
    The pics don't provide enough info but in the top pic it looks like the fret slots are different depths which suggests refret.
    I can't even see the maple cap board in either pic, which the '67 should have.
    Clues we use include amount of wear on the neck and board vs amount of wear on the frets, condition of finish on the board along the edges of the frets, finish over the ends of the frets etc.
  5. Lotion12
    Ankara
    Its not mapple cap neck. It has a stripe on it,
  6. aging_rocker
    aging_rocker Tele-Holic
    The upsidedown
    Yep, unless it's spent most of the time in the case I'd always assume it's had a refret. So long as it's been done well, it doesn't matter.
  7. unixfish
    Northeast Ohio, USA
    Does that change the value though? I go back to my brake pad analogy - it would not for a classic car, unless it was bought, stored without being driven, then sold decades later.
    I'm not questioning you - I am truly curious.
  8. ElJay370
    ElJay370 Tele-Holic
    Los Angeles, CA
    Originality is the key component in a vintage guitar’s value.
    A guitar that has its original frets will always be worth more than one that doesn’t.
    Even though a refret is part of keeping a guitar in good playing condition, how well an instrument plays is almost irrelevant in the crazy world of vintage collecting.
  9. aging_rocker
    The upsidedown
    Yes, it would reduce the value to me, because I'd need it refretted. I buy guitars (and cars) to use them, so worn out frets or brake pads would make it useless to me.
    A very different story if you are buying what is essentially a 'museum-piece' guitar, or car.
    Agreed. I don't buy antiques.
    CCK1 likes this.
  10. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Top one's looks like it got Dunlop 6105 med jumbos. If it's not a maple cap (should be no skunk stripe) it's not original to the body or there's another issue. More pics needed.
    Looks like a good pro job. Bottom one could be original. Need to see the other side of the fretboard.
    telemnemonics likes this.
  11. Stratwrangler
    Stratwrangler Tele-Meister
    The world
    Is this a quiz ? Top one looks re fretted but neither of them look like maple capped in those pics and the 67 should be shouldn't it .
  12. telemnemonics
    I may be having a senior moment but a ‘67 should be a maple cap neck.
    As others have also mentioned.
    Refret makes little difference if the neck isn’t even original to the guitar.
    Seems like all original is what ever seller calls every old guitar these days.
  13. Middleman
    Middleman Friend of Leo's
    MV, CA
    If the color of the fretboard is lighter than the headstock, which is generally yellowed over time, then it's been refretted because they would likely sand down the fretboard refret and then spray a finish. Early and mid 70s necks were 7.25 radius that's a telltale as well. If the ends of the frets are nicely curved like the ones in your pictures, I would suspect a refret because I have a 74 and it's not as nicely finished on the ends.
    landofahhs likes this.
  14. unixfish
    Northeast Ohio, USA
    Yep - I did not think of that. Some of those prices are nuts.
    The OP is looking for a player guitar (what I got from his post) and not a collector guitar. If I'm looking at a player and not an investment, then there are a few things I'm willing to overlook. If is has new / newer frets from a refret - no biggie. I could be in the minority here. But, then again, I'm not looking to buy a vintage guitar either, so $0.02 and all that.
  15. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    Both of those necks have been refretted. The frets shown are wider than stock.
    The color of maple capped necks from the poly years is *always* lighter than the headstocks, especially these days. Even on poly finished necks, the headstock faces were finished in lacquer, which yellowed significantly faster than the poly on the rest of the neck.
  16. toomuchfun
    toomuchfun Tele-Afflicted
    PA, US
    May not be much help. but here's my '75 standard Tele with original frets.
  17. Lotion12
    Ankara
    Hi guys, that guitar bought from guitar center, it has 1967 body and 1968 neck. I check the dates from neck and body stamp . Maple neck 5D38DC28-8F9A-4538-8AB4-24B70962965C.jpeg 52DA809C-BE0F-4376-842F-30D87A09EA6D.jpeg BF135782-8BA0-4D73-B507-2A83FD4C6EB1.jpeg 3EABB479-3C6C-4D2D-B68C-580742FC196B.jpeg FCE72CE2-49B8-4F92-8FD0-9382117F5B07.jpeg B813A9EE-52A7-4FF3-9CB9-66DA9656C11B.jpeg 463D4FAF-98F5-4257-A325-2114CFB02338.jpeg 1849133D-CC59-4505-8C36-B10D3DB809E4.jpeg D4E5FB45-480D-4954-9359-39E8F0BC17A2.jpeg 6A499DCC-CB3B-4FAB-B6DD-6E28641D0B13.jpeg With a skunk stripe. Its factory bigsby model.
    Here is some photos
  18. Lotion12
    Ankara
    at the first post, the first one is Telecaster Factory Bigsby.the second photo belong to my 1973 Telecaster deluxe,
    I live in Turkey, its not that easy to reach that vintage and valuable guitars in my country.
    So i really respect it and would prefer play them without refret , if they didnt refretted.
    But if i ll be sure with your kind helps and supports about any of them refretted before me i ll definetely refret it again.
    the other case is 1973 Telecaster Deluxe which one appears in second photo of my first post. im absolutely sure that guitar has original frets.
    For both guitars. if the frets are original, i would play them until they become unplayeble. But as i said if i spot refret, i ll definetely go refret again..
    Both guitars are plays well, but if i refret them they will be much more comfortable.
  19. Chunkocaster
    In space with Ziggy
    I'd be thankful if they had the frets replaced, especially if they weren't vintage spec.
  20. Lotion12
    Ankara
    in my opinion, if it has original frets and plays well even if its not that comfortable at all , keep frets and keep rocking with it until the end.
    Because if i buy a 68 mustang it wont be comfortable as 2019 mustangs. but it is vintage its pretty normal. it has mojo and sound and feeling. it always worth ..
    playing without really comfort as modern guitars is like a challenge for me on stage and tours :D
    Antoon likes this.
