How to re-use these tubes
Discussion in 'Amp Central Station' started by tanplastic, Apr 18, 2021.
  1. tanplastic
    tanplastic Tele-Holic
    I can see your house from here.
    The following tubes are currently in an old mono phono amp.
    2 RCA 6AV6
    1 RCA 6V6GT
    1 Marconi 5Y3GT
    1 Rogers F5E
    Rogers H5E
    I know the 6V6GT is a direct replacement for my DRRI.
    I'm hoping a fellow TDPRI member is familiar with the other tubes and can suggest a use for them.
    Thanks for reading.
    Jerry
  2. Lowerleftcoast
    california
    The 5Y3GT is a rectifier tube. The Tweed amps such as the Tweed Deluxe use this tube.
    The 6AV6 is half of a 12ax7. It is used in amps such as the Harvard.
    I am not familiar with the F5E or H5E.
    tanplastic likes this.
  3. Wally
    Tube Data Sheet Locator gives negative results for both the F5E and the H5E.
    http://tdsl.duncanamps.com/tubesearch.php
    In order to use that 6V6 in your DRRI, you would want another 6V6 that was somewhat of a match for it....and you would want to know that it was not shorted before installing it.
  4. tanplastic
    Thank you, Wally, for the link and the advice.
    J
  5. ArcticWhite
    ArcticWhite Tele-Afflicted
    Portland Oregon
    Don't toss the amp either.
    It could be converted to a small Tweed Champ amp. Sell it or give it away if you don't want to do it.
    BobbyZ and tanplastic like this.
  6. Ringo
    Ringo Poster Extraordinaire
    Memphis TN
    Old tubes can be good , or just worn out, I wouldn't toss them but if you know anyone with a good tube tester have them checked.
    tanplastic and BobbyZ like this.
