How to model a tele style neck for CNC work.... new and improved...same low price
Discussion in 'Tele Home Depot' started by guitarbuilder, Feb 16, 2021.
  1. guitarbuilder
    I'm putting a couple points at the widest part. I had them at the last fret but I moved them to this spot.
    crazydave911 likes this.
  2. guitarbuilder
    Next using the arc tool, I make a 9.5" radius line between the two points.
  3. guitarbuilder
    And then I copy it to the fretboard plane.
  4. guitarbuilder
    and delete the top one
  5. guitarbuilder
    Now I can extrude that line and create a radiused surface. I extrude it beyond the nut transition area
  6. guitarbuilder
    So now that we have a fretboard surface I am going to try something new and draw in the fret slots. I making the slot 1/16" deeper than the edge of the fretboard. That is a surface and I extruded that into a solid in both directions by .011. I will put a point right at the top of the middle of top dead center.
  7. guitarbuilder
    I copy that fret slot and place it at each fret line location that Ed drew.
  8. guitarbuilder
    Now I will draw in the thickness of the fretboard wood around it.
  9. guitarbuilder
    I draw in the fretboard sides. There are quite a few different ways to do that, the easiest being draw lines, create a planar surface out of them.
  10. guitarbuilder
    Now I flipped it upside down and made the bottom of the fretboard. I use sweep two rails with the highlighted line in yellow.
  11. guitarbuilder
  12. guitarbuilder
    And the last thing for today...I'll just cut out some lines and show the fretboard with slots....it'll still need to be tapered later.
    crazydave911 and photondev like this.
  13. Engraver-60
    Engraver-60 Friend of Leo's
    Brentwood, TN
    Looking good, Marty.
  14. GeminiCG
    GeminiCG Tele-Meister
    Fort Collins, CO
    Wow, as someone who wants to build guitars for a living after college, this is most helpful as I plan on using CNC in the future. Maybe some lessons from you would be nice.
  15. guitarbuilder
    Thanks Mark!
  16. archetype
    archetype Fiend of Leo's
    Williamsville NY
    That's pretty cool. It looks like a lot of work, but a lot of work only once.
    How would a CNC rough in the back profile? Do you digitize an existing neck for X, Y, and Z, and then program to that data set?
  17. guitarbuilder
    Thanks. If you can, take a college Cad class or two. Also get an education copy of some 3D software that you like the looks of. Rhino had an educator's and student discount that made it sort of affordable.
  18. pshupe
    pshupe Tele-Meister
    Hamilton
    Fusion 360 is free for hobbyists and all Autodesk software is free to students.
    CAM software these days just take the 3d model and carve out what ever isn't there. Like Michelangelo said when asked how he sculpted David. He said he just took out the pieces of rock that were not David.
    I used Rhino for a while and find Fusion 360 a little easier and more intuitive. I sketch in AutoCAD import into Fusion and just push and pull into solids.
    Here is a typical guitar model in Fusion 360 -
    Cheers Peter.
    crazydave911 and guitarbuilder like this.
  19. GeminiCG
    Fort Collins, CO
    I have a background in Fusion 360 because of high school, but it has been a while since I last used it.
  20. guitarbuilder
    Ok back at it ....now comes the hard part. the curved surfaces. Here's how I left it.
